2000 DI6Y7 TURBO
Old Apr 25, 2007 | 08:15 AM
00D16Y7's Avatar
Default 2000 DI6Y7 TURBO
I have a 2000 civic dx and i bought a g-reddy turbo kit for it, the car is pretty much stock except for an unorthodox undrive pulley, cold air intake, and highflow cat. the kit came with a vortec fmu but will i need to upgrade the injectors anyway?
Old Apr 25, 2007 | 08:20 AM
dannis.'s Avatar
Default Re: 2000 DI6Y7 TURBO (00D16Y7)
IMO it would be a good idea to.
Old Apr 25, 2007 | 08:23 AM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: 2000 DI6Y7 TURBO (DannisEG6)
on low boost you can get away with it... but i'd go ahead and invest in some bigger injectors and a OBD-1 conv so it can be cromed or whatever ..its up to you but people run those kits everyday with stock injectors on a FMU
Old Apr 25, 2007 | 08:39 AM
97Ej6mike's Avatar
The stock 240cc Injectors work great, especially with the FMU. I had a friend that used to run 10psi as a DD in his Y7 hatch, and that thing hauled. D series <3 boost, lol
Old Apr 25, 2007 | 08:44 AM
00D16Y7's Avatar
Thanx a lot for the quick responses How much hp can the d16s handle before the engine and or tranny start to fail? i hav a auto tranny and the car onnly has 74,000 on it. One other question how hard is to put the turbo kit in and also keep the a/c. I have heard that it really tight and difficult to keep the a/c, but i heard from other people that it is possible.
THANX AGAIN GUYS
Old Apr 25, 2007 | 08:54 AM
97Ej6mike's Avatar
You'd prob blow the motor before you blow the tranny
Old Apr 25, 2007 | 09:59 AM
ddd4114's Avatar
With an auto tranny, I'd recommend that you install an oil cooler. As long as you don't drive like an *** all time, it should hold up for a decent amount of time.
Old Apr 25, 2007 | 10:08 AM
slowex98's Avatar
injectors sound good may also want to look into gettina a high flow fuel pump
Old Apr 25, 2007 | 11:43 AM
97Ej6mike's Avatar
Ive never actually heard of some boosting an automatic. Keep us posted on how the build goes, and how well it performs
Old Apr 25, 2007 | 11:54 AM
uneek360's Avatar
Default Re: (97Ej6mike)
My friend is boosting his automatic...lol. I also wanna see how it works out.
Old Apr 25, 2007 | 12:40 PM
Eddieman201's Avatar
FYI the D16Y7 has 190cc injectors, the Y8 has 240cc injectors.
Old Apr 25, 2007 | 12:42 PM
highrev1987's Avatar
Default Re: 2000 DI6Y7 TURBO (slowex98)
fuel pump is not necessary,
OBD1, DSM blue tops and tune
PS: The D16Y's have the crappiest oil pumps
Old Apr 25, 2007 | 05:41 PM
97Ej6mike's Avatar
Default Re: (Eddieman201)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddieman201 &raquo;</TD></TR><TR><TD CLASS="quote">FYI the D16Y7 has 190cc injectors, the Y8 has 240cc injectors. </TD></TR></TABLE>
You sure about that?
Old Apr 25, 2007 | 06:16 PM
i'm almost positive but i'll check on it
Old Apr 25, 2007 | 06:36 PM
kramitman87's Avatar
from everything ive heard an automatic tranny from a d16 will rip itself apart once boost. this is what i was told but i was planning on running around 23 psi. people were telling me that the auto tranny wouldnt hold anything over around 170ft/lbs of torque so if you think you are going to have over that you may want to rethink things. i ended up doing a manual conversion again this is just what ive heard from others so i dont know if the tranny will really "die" as they all claimed. just my two cents
Old Apr 25, 2007 | 06:55 PM
97Ej6mike's Avatar
Default Re: (kramitman87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kramitman87 &raquo;</TD></TR><TR><TD CLASS="quote">from everything ive heard an automatic tranny from a d16 will rip itself apart once boost. this is what i was told but i was planning on running around 23 psi. people were telling me that the auto tranny wouldnt hold anything over around 170ft/lbs of torque so if you think you are going to have over that you may want to rethink things. i ended up doing a manual conversion again this is just what ive heard from others so i dont know if the tranny will really "die" as they all claimed. just my two cents</TD></TR></TABLE>
23 psi is wayyyyy too much for stock internals, let alone an auto tranny. Your not like running a 2jz or 4g63, lol, its a D16, i woudlnt go higher than 10 PSI max. 6-8 PSI is the recomended setting by most boost know-it-all's
Old Apr 26, 2007 | 09:24 AM
well im doing full internals though... thats why im doing 23 psi
Old Apr 26, 2007 | 10:20 AM
cycoclown's Avatar
my friends d16y8's Connecting rods took a **** on him when he put his turbo on it. maybe it would be a good idea to change them out of a y7.
Old Apr 26, 2007 | 10:32 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">
You sure about that?</TD></TR></TABLE>
Yeah, the Y7 sports 1**cc's while the Y8 and Z6's sport 240's.
* = I forgot what exactly, think it's 190, but I know it was under 200
yeah, the tranny will get owned. 5/6g civic auto tran's are suckers in both endurance, and putting power to the ground.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cycoclown &raquo;</TD></TR><TR><TD CLASS="quote">my friends d16y8's Connecting rods took a **** on him when he put his turbo on it. maybe it would be a good idea to change them out of a y7.</TD></TR></TABLE>
No need, your friend was just an idiot and either did one of three things:
A) Put too much tq. through the motor on stock internals (tried turning up the PSI).
B) Boosted a weak ***, falling apart engine
C) Was a moron and didn't tune it right (or at all) ** Most likely **
Don't swap anything out, this guy's friend is just a *******. The stock internals will hold fine, about 200whp on a dyno tune is about where I'd stop trusting them - assuming you're running like a 12.3A/F - run a bit conservative. Maybe 170 if you're doing an estimated hp # based on a street tune.
Old Apr 26, 2007 | 10:46 AM
cycoclown's Avatar
Default Re: (Syndacate)
lol, its true.
Old Apr 26, 2007 | 10:55 AM
Syndacate's Avatar
Default Re: (cycoclown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cycoclown &raquo;</TD></TR><TR><TD CLASS="quote">lol, its true.</TD></TR></TABLE>
lol
Old Apr 26, 2007 | 01:23 PM
yeah i'm defintitely sure the Y7's have 190's
Old Apr 26, 2007 | 03:35 PM
HXvtec's Avatar
the way gas prices are now i would keep the stock injectors and run low boost
Old Apr 26, 2007 | 03:55 PM
Throwdown's Avatar
Default Re: 2000 DI6Y7 TURBO (HXvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXvtec &raquo;</TD></TR><TR><TD CLASS="quote">the way gas prices are now i would keep the stock injectors and run low boost</TD></TR></TABLE> x2 its getting retarded here in FL
Old Apr 26, 2007 | 04:43 PM
blackhatch96's Avatar
I don't know what it is in FL but its $3.25 for reg up in Wa. like 3.55-65 for premium
