VTEC Malfunction
Old Apr 25, 2007 | 06:57 AM
FOOLS_Si's Avatar
Default VTEC Malfunction
my check engine light came and spit out a code that was P1259 which i looked up and said that it has to deal with the vtec mal.. i have heard some things about an oil pressure switch and i might need to scrape off the sludge. can anyone tell me where the switch is located and how would i go about doing this? or any other suggestions to what is wrong.
i jus searched a little more and now i found that the code means Immobiliser to PCM signal error
Old Apr 25, 2007 | 07:54 AM
93egsir's Avatar
Default Re: VTEC Malfunction (FOOLS_Si)
If you clear the code does it come back or not? if it does the vtec oil pressure switch is a 2 wire usually green plug that is near the exhaust cam end cap. on the distributor end of the motor.
Bump
Sep 28, 2005 04:12 PM
drudy
Aug 26, 2005 12:20 PM
drudy
Aug 7, 2005 05:59 AM
Blake97GSR
Nov 7, 2003 06:01 AM
slackeR1366
Dec 29, 2001 01:44 PM
