traling arms
Old Apr 24, 2007 | 05:14 PM
aarontrini85's Avatar
Default traling arms
my damn traling arm is trashed on my 91si i was woundering if i can just remove my hub and put it on a drum brake traling arm? and use my disk brake or is there some sort of issue with that?
Old May 8, 2007 | 06:29 PM
Default Re: traling arms (aarontrini85)
bump
Old May 9, 2007 | 03:31 AM
Old May 9, 2007 | 05:12 AM
ChickenH's Avatar
how is it trashed? the big bushing can be replaced with an energy suspension one if thats the problem.
Old May 9, 2007 | 09:21 AM
Default Re: (ChickenH)
the bolt for the lca broke off and thers not enough to grab.
i tried to chisle off the old nut that it threads in to and its tearing away to much of the metal that i would need to weld the new one on to.
trust me its trashed lol
Old May 9, 2007 | 09:51 AM
redefsir's Avatar
Default Re: (aarontrini85)
you can use a drum brake trailing arm.
im pretty sure
good luck
Old May 9, 2007 | 12:29 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (redefsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redefsir &raquo;</TD></TR><TR><TD CLASS="quote">you can use a drum brake trailing arm.
im pretty sure
good luck</TD></TR></TABLE>
Yes it sure does work. You will probably have a hell of a time getting those T50 torx bolts and giant nut off the back though...
Here is a recent thread from the suspension forum:
https://honda-tech.com/zerothread?id=1962350
Old May 9, 2007 | 01:52 PM
Default Re: (94eg!)
awesome thanks and i got a nice 1/2 inch socket with a t50 on it so hopefully its not that bad
once again thanks and ill let every one know if i ran in to any trouble
Old May 9, 2007 | 09:13 PM
same ol Steve's Avatar
hit the torx head bolts with a torch to make the locktite break down that seems to help
VegasEg8
27
May 16, 2014 11:38 PM
SOHC4life 96
Apr 18, 2008 04:00 PM
Hella_Fresh
Aug 19, 2005 12:56 AM
teg94
Aug 24, 2001 04:33 AM
