Sidemarker Help!!!!! ASAP!!!!
O.k. I'm trying to wire up my sidemarkers like in the other threads but they are kind of shady on the wires. I want my sidemarkers to stay on with the corners and blink when I put the turn signals on. Well I tapped into the green wire and red wire but when I turn my corners on nothing happens. When click to turn the turn signal left they blink. But when I click it to turn on the right blinker all the lights come on. So what am I doing wrong? Thanks
You need to learn to use a multimeter or test light. If you knew that, you could easily determine where to tap the wires, by yourself. So run "how to use a test light" or "how to use a multimeter" through google or ask jeeves. It's a valuable skill and you will use it for the rest of your life.
Your other option is to look at a service manual. It sounds like what you are trying to do requires the use of a relay and you should also research Single Pole Double Throw (SPDT) relays.
O.k. well I wired up up my the red wire to the red wire and the black wire to the green wire and the blinkers and sidemarkers blink but the corners lights do not come on
O.k. I just re-wired everything back how it was and my running lights will not come on for anything. I replaced 2 fuses that were blown but still nothing. The blinkers will come on but not my running lights. Please someone help me
Does your cluster light up? If not you crossed a wire causing the tail running lights, corners and cluster fuse to blow again. Make sure your wires are not crossing where you had them tapped in.
-iLLuZioN-B18C1
Oct 25, 2009 05:50 PM
