5mm spacer?
Old Apr 24, 2007 | 11:49 AM
kleen98accord's Avatar
Default 5mm spacer?
would i need to get a hub centric 5 mm spacer? im thinkin no because 5 mm isn't that big. any advice would help? i don't know where to get them either. some sites have them and their for the 5 x 100 pattern. i need a 4 x 114.3.
Old Apr 24, 2007 | 11:53 AM
r.wright's Avatar
Default Re: 5mm spacer? (randomvtec)
h&r makes them hubcentric
but if i need one real quick i just hit up pep boys or any wheels store.
Old Apr 24, 2007 | 01:00 PM
nsxtasy's Avatar
H-T Order of Merit
I don't think there is such a thing as a hubcentric 5 mm spacer. I could be wrong, but I don't think so. Here's why.
There are two basic kinds of spacers. One is a thin metal plate, which does not do anything in the way of centering the wheels. It's typically used for small spacing, like 3 or 5 mm. It looks like this:
The other is a thicker version which bolts to the hub and has its own new set of lugs (studs). This hubcentric kind is often called a "hub adapter" and is usually used for large spacing, like 15-25 mm or more. It looks like this:
I don't think you can find the hubcentric kind of spacer in a thickness as thin as 5 mm. There just isn't room for the lugnuts to attach it to the hub.
Old Apr 24, 2007 | 02:18 PM
Default Re: 5mm spacer? (nsxtasy)
thanks guys
Old Apr 25, 2007 | 10:17 AM
dualweberVW's Avatar
I have some, H&R makes 5mm
Edit: I have them in 4x100, but I don't see why they wouldn't have 4x114.3. If not there's websites what will make them, or a machinist, economically
Old Apr 25, 2007 | 02:07 PM
r.wright's Avatar
Default Re: 5mm spacer? (dualweberVW)
http://www.optionimports.com/10245616a.html
Old Apr 25, 2007 | 09:49 PM
broketuner-Sol_Si's Avatar
Default Re: 5mm spacer? (mr. R*L*X)
would spacers be good to get the track of the car wider for a high offset set of wheels? I currently have a set of +45 on my del sol and the look really sunk in:
I really don't want to sell them for a lower offset, so I'm hoping the spacer idea would be safe.
Old Apr 26, 2007 | 06:26 AM
hoaxs's Avatar
you can go to a machinest and get some made. Try to stay away from the pepboys spacers cause there made from like pop metal that crack easy.
Old Apr 26, 2007 | 08:06 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 5mm spacer? (broketuner-Sol_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by broketuner-Sol_Si &raquo;</TD></TR><TR><TD CLASS="quote">would spacers be good to get the track of the car wider for a high offset set of wheels? I currently have a set of +45 on my del sol and the look really sunk in</TD></TR></TABLE>
They can do that, but I wouldn't. For one thing, I don't think those look sunk in at all; they look fine to me. For another, keep in mind that if you push the wheels/tires out more, they will kick up more gravel and road debris and damage the finish of your car behind the wheel wells. I would just stick with what you've got.
Old Apr 26, 2007 | 08:17 AM
Looks worse in person IMO. as for them kicking up more debris, I'm not too worried about that because I'll be installing the mudguards soon.
Old Apr 26, 2007 | 01:30 PM
i think you should get a hubcentric spacer because it seems like you'll need more then 5mm.
Old Apr 26, 2007 | 01:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
so for that kind I would need to remove the OEM studs, and then just install that and torque it down onto the hub?
I agree I think I will probally want more than 5mm after looking at the gap in person and up close about 15-20mm or so up front and mybe 10-15mm in the rear
Old Apr 26, 2007 | 06:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by broketuner-Sol_Si &raquo;</TD></TR><TR><TD CLASS="quote">Looks worse in person IMO. as for them kicking up more debris, I'm not too worried about that because I'll be installing the mudguards soon.</TD></TR></TABLE>
yes, go wide.
That_Delsol_Guy
Dec 27, 2015 06:54 AM
Kris05TSX
Sep 29, 2013 09:44 AM
DUKE LADUKE
Suspension & Brakes
19
Feb 16, 2011 11:08 AM
CanuckEJ6
Jun 21, 2008 02:32 AM
Seann
Oct 30, 2001 01:47 PM
