Mixing oil
Old Apr 24, 2007 | 10:17 AM
B16b-EJ8's Avatar
Default Mixing oil
Quick question, I noticed i am about 1 quart low on oil, currently in the engine is Motul 5w30 dont really want to spend 40 bucks to add one quart since i can only get it in the big cans...so can i just grab some Castrol synthetic or something in the mean time or is it not a good idea to mx two different types of oil
Old Apr 24, 2007 | 10:23 AM
Padawan's Avatar
Darth ModerVader
Default Re: Mixing oil (B16b-EJ8)
Yes, that's fine. Just be sure to use the proper viscosity.
Old Apr 24, 2007 | 10:26 AM
B16b-EJ8's Avatar
Default Re: Mixing oil (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Yes, that's fine. Just be sure to use the proper viscosity. </TD></TR></TABLE>
thanks, i will make sure its 5w30
Old Apr 24, 2007 | 11:08 AM
Blk00EJ8's Avatar
Isn't that not such a great idea? The characteristics (temp vs. viscosity) of even similarly rated oils across brands is different.
Old Apr 24, 2007 | 11:13 AM
B16b-EJ8's Avatar
Default Re: Mixing oil (Blk00EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blk00EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
Isn't that not such a great idea? The characteristics (temp vs. viscosity) of even similarly rated oils across brands is different.</TD></TR></TABLE>
I actually did some searchin in the archives and almost everyone had the same opinion that it will be fine. I cant imagine that my engine would blow up by adding 1 quart of oil that wasnt the same as what is in there(so long as they are the same weight)...besides that the head is getting pulled off in 2 weeks to get rebuilt so it will get an oil change then. I'm thinking i should be safe.
Old Apr 24, 2007 | 11:25 AM
Blk00EJ8's Avatar
In that case, more power to you
(get it? more power... rebuild! anyway...)
Old Apr 24, 2007 | 11:30 AM
B16b-EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blk00EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">In that case, more power to you
(get it? more power... rebuild! anyway...)</TD></TR></TABLE>
Got it!
Old Apr 24, 2007 | 11:51 AM
ridin98civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
Got it! </TD></TR></TABLE>
good!
Old Apr 24, 2007 | 11:57 AM
TDSI99's Avatar
Default Re: Mixing oil (ridin98civic)
I have mixed oil and nothing ever happend. And if you are pulling you head.....go for it
Old Apr 24, 2007 | 02:26 PM
Agent_EM1's Avatar
Default Re: Mixing oil (TDSI99)
Yeah as mentioned above. Just use the same kind of oil you used with the motul. Shouldn't be a problem. One time, I used all Royal Purple and needed an extra quart so I bought some Penzoil Platinum and it worked out great.
Old Apr 24, 2007 | 03:21 PM
RedRocketDX's Avatar
I make **** mixes of oil all the time. Synthetic, conventional, different brands, and weights. It's all good! No problems at all.
Old Apr 24, 2007 | 03:49 PM
spotscivic's Avatar
yea..im shur it would be just fine until next time you change it. just make shur you use the same weight in the oil.
Old Apr 24, 2007 | 03:52 PM
B16b-EJ8's Avatar
Default Re: Mixing oil (spotscivic)
Thanks all, ended up going by the shop that does the work on my car and they topped me off with some Motul for free. Good info for th next time or the next person that asks
Old Apr 24, 2007 | 03:57 PM
h2392si's Avatar
Your going to be ok.
s2k5
Honda S2000
21
Sep 22, 2007 08:44 PM
Kwayzie
16
Mar 20, 2007 04:28 PM
nexgen91
Nov 6, 2006 02:11 PM
TurboEG6
38
Aug 31, 2006 07:55 PM
S2000Forsale
Honda S2000
39
Oct 1, 2005 09:13 AM
