what type of cams should i get for my relatively stock B16
i was just wondering peoples ideas on what cams i should get for my relatively stock b16. also what pros and cons im lookin at if i go with that particualr cam. so far i have been lookin at blox htr stg 3 cams with titanium springs and retainers selling for $700. please anyone give me input on what they think...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">What are your plans for the engine?</TD></TR></TABLE>
Probbly good to know.
Pros and cons on each cam will varry alot, you really need to give us as much info as you can so we can help you pick
for stock, i wouldnt use anything over a stage one, which will still allow you to use your stock valvetrain, assuming you dont rev any higher. itr/ctr cams are a pretty good cam for the price, as you can find them around 300 bucks used, for the pair.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heylookits shawn »</TD></TR><TR><TD CLASS="quote">for stock, i wouldnt use anything over a stage one, which will still allow you to use your stock valvetrain, assuming you dont rev any higher. itr/ctr cams are a pretty good cam for the price, as you can find them around 300 bucks used, for the pair.
X2
X2
GSR cams on a b16 and near IDENTICAL on a dyno chart with a 3+hp gain and equal torque i believe.
not worth doing all that work for a negligable power gain.
as of now i have intake and exhaust. i plan to do header, high flow cat, and possibly type r intake manifold(if its worth it). then i would like like to do cams but i was confused as to which ones i should go with, but at the same time i would like some decent hp gains (who doesnt!). but really thats all i plan to do just to make it at least somewhat quick...
also i would like to add i dont mind spending the extra money to do springs and retainers i would just like to kno if the blox stage three cams along with the springs and retainers would be worth it...
i went with itr cams and manifold because my cousin had them laying around. i also went with crower valvetrain. dual springs, retainers, and valves.
i cant complain. it pulls good. chirps fourth...so i cant complain. i'm sure that i can get a bit more out of them with a good tune.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodcivic510 »</TD></TR><TR><TD CLASS="quote">GSR cams on a b16 and near IDENTICAL on a dyno chart with a 3+hp gain and equal torque i believe.
not worth doing all that work for a negligable power gain.</TD></TR></TABLE>
thats with a newer style b16 ^^ . the obdo 1st gen b16 had some really crappy cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">thats with a newer style b16 ^^ . the obdo 1st gen b16 had some really crappy cams</TD></TR></TABLE>
yeah, and if you got an automatic b16, you would probably feel more of a pull if you took the cams out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brnvle »</TD></TR><TR><TD CLASS="quote">as of now i have intake and exhaust. i plan to do header, high flow cat, and possibly type r intake manifold(if its worth it). ...</TD></TR></TABLE>
The cams are cool, i wouldn't bother with the Type R manifold though, its proven the 2nd gen B16 intake (P30) gives more power up untill 8000rpm, so it a better choice in terms of an upgrade. Heck, even on full B20 vtec conversions, the P30 made more power.....something to think about.
im just curious as to why most of u are stearing me away from bigger cams such as the stage three...will it not make much of a horsepower gain???...and if i do go stage 3 (blox stg 3) what else should i consider besides the valve springs and retainers???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brnvle »</TD></TR><TR><TD CLASS="quote">im just curious as to why most of u are stearing me away from bigger cams such as the stage three...will it not make much of a horsepower gain???...and if i do go stage 3 (blox stg 3) what else should i consider besides the valve springs and retainers???</TD></TR></TABLE>
Answer is easy....
You NEED really high compresion to get good power out of big cams, as well as spring, retainers, and most definitly some quality tuning as stock spark/fuel maps won't really cut it
Answer is easy....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz »</TD></TR><TR><TD CLASS="quote">
Answer is easy....
You NEED really high compresion to get good power out of big cams, as well as spring, retainers, and most definitly some quality tuning as stock spark/fuel maps won't really cut it</TD></TR></TABLE>
exactly.
Answer is easy....
exactly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">why spend that much on BLOX cams, when ITR/CTR are cheaper and will give probably the best gains considering the mods you have done now. </TD></TR></TABLE>
stage 3's will require at least 12:1 compression to make good power
i have type-r cams in my b-16 and i love it like that, when my vtech opens its ridiculously loud, everyone looks
did u notice the power gains...in other words is it worth it for me to pay for those and have them installed...?
88cerx
12
Nov 29, 2005 10:42 AM
