Car wont start after valve lash
Old Apr 24, 2007 | 06:54 AM
Boostedb20EH2's Avatar
Default Car wont start after valve lash
I did a valve lash last night and only adjust 2 of them in cylinder 3 (yes i did it correctly at tdc) And now my car will not start when i tried. Im going to try to figure it out with a mechanic tonight. But anything i should look for first? It can start put i have to give it throttle and runs really rough.
Old Apr 24, 2007 | 07:08 AM
THC07's Avatar
Default Re: Car wont start after valve lash (Boostedb20EH2)
too tight
Old Apr 24, 2007 | 07:15 AM
H9Omega's Avatar
Yeah, obviously they are too tight, you sure you are adjusting them correctly?
Old Apr 24, 2007 | 07:21 AM
Luserkid's Avatar
Default Re: (H9Omega)
Did you do the 2 when the motor was TDC or when the cylinder was TDC? You need to get each cylinder TDC to do them (mainly just the head)
With the cams up thats cylinder 1
Cams pointing left: 3
Cams point down: 4
Cams point right: 2
http://www.c-speedracing.com/h...t.php
Old Apr 24, 2007 | 10:22 AM
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Did you do the 2 when the motor was TDC or when the cylinder was TDC? You need to get each cylinder TDC to do them (mainly just the head)
Cams point down: 4
Cams point right: 2
http://www.c-speedracing.com/h...t.php</TD></TR></TABLE>
Like i said i know all of this. Im pretty sure they were to spec also.
drumminforev
Oct 13, 2006 08:52 PM
drumminforev
Oct 13, 2006 11:36 AM
wildoutwhitegsr
Jan 27, 2006 08:42 PM
OnDaBottle
Oct 20, 2004 12:10 PM
magic hat #9
Aug 2, 2004 09:08 AM
