SKunk2 Camber kit 95 EG, Steering has mind of it's own....
Old Apr 23, 2007 | 10:58 PM
EGJason's Avatar
Default SKunk2 Camber kit 95 EG, Steering has mind of it's own....
I installed skunk2 front and rear camber kits, then had it professionally aligned. About 6 months later, the tread on both front tires has dwindled down to nothing, and when I take a corner, the steering wants to force itself in that direction. Also, the steering wheel seems to shift about 10 degrees off in various directions when driving strait.
Any ideas as to what I should adjust/have someone look at?
Old Apr 24, 2007 | 03:06 AM
jg's Avatar
jg
Default Re: SKunk2 Camber kit 95 EG, Steering has mind of it's own.... (EGJason)
Yikes! Have you checked to see if the bolts that hold the ball joint in place have loosened?
Old Apr 24, 2007 | 03:25 AM
EK9Rider's Avatar
Default Re: SKunk2 Camber kit 95 EG, Steering has mind of it's own.... (jg)
did you rotate the tires? the tires play a big part if they are directional tires not installed properly.
check everything
did they tighten everything????
Old Apr 24, 2007 | 06:40 AM
EGJason's Avatar
Default Re: SKunk2 Camber kit 95 EG, Steering has mind of it's own.... (EK9Rider)
Yes, I just rotated the tires yesterday. The ball joint seems snug as a bug in a....
baca00ex
20
Oct 19, 2010 06:43 PM
94CDMeg
Sep 4, 2008 08:49 PM
ware
Suspension & Brakes
10
Apr 7, 2007 10:44 AM
sohctodohc
Nov 15, 2005 07:03 AM
kcem1
Suspension & Brakes
Aug 4, 2005 02:43 PM
