engine noise
hey guys i need some help.i did a swap on my eg with a z6 and slap on a garrette t2.before i got the mbc(manual boost controller) it was only boosting 5lb.it sounds pretty quite but when i adjusted to boost 10lb its making weird noises.
the sound i'm assuming its coming from somewhere in the altornator belt or timing. it makes a click noise from 2nd,3rd to 4th gear.any ideas what it might be?
Sounds like you need to get your car tuned. Also, you might have better luck here
https://honda-tech.com/zeroforum/16
