stroking a d15b7...
Old Apr 23, 2007 | 09:29 PM
b16nonoy's Avatar
Default stroking a d15b7...
any good combinations too get more displacement on my d15b7? want to use my stocke sleeves...also doing a vtec swap on it.
Old Apr 23, 2007 | 11:45 PM
ddd4114's Avatar
Default Re: stroking a d15b7... (b16nonoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16nonoy &raquo;</TD></TR><TR><TD CLASS="quote">any good combinations too get more displacement on my d15b7? want to use my stocke sleeves...also doing a vtec swap on it.</TD></TR></TABLE>
Why not buy a d16 vtec engine and drop it in?
Old Apr 24, 2007 | 05:06 AM
LS-V Turbo's Avatar
Default Re: stroking a d15b7... (ddd4114)
why would you stick money into that motor it just doesn't make scense. I agrre buy a d16z6. Parts are cheep and there are tons of them and you can make alot more power from that then a mini me swap.
Old Apr 24, 2007 | 12:29 PM
b16nonoy's Avatar
Default Re: stroking a d15b7... (LS-V Turbo)
I just want my original engine anymore..took out my b16 that I blew up...
Old Apr 24, 2007 | 12:50 PM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16nonoy &raquo;</TD></TR><TR><TD CLASS="quote">I just want my original engine anymore..took out my b16 that I blew up...</TD></TR></TABLE>
I assume you mean "I want my original engine"?
Either way, you want to dump hundreds of dollars turning your d15b7 into a "d16z6" when you can just buy a d16z6 and drop it right in? Why?
Old Apr 24, 2007 | 02:51 PM
b16nonoy's Avatar
cant I just pick up a d16 crank and rods and it would work?
Old Apr 24, 2007 | 02:52 PM
b16nonoy's Avatar
should I go with a ZC or a d16z?..will B-series cams work in the DOHC. zc?
Old Apr 24, 2007 | 03:42 PM
eg8tuner's Avatar
the d16 has bigger oil journals that the d15 so no it wont work
HondaTeKnology
Dec 9, 2007 04:28 PM
99cilvercivicEX
20
Dec 21, 2006 08:13 AM
Stevegunit16
Dec 16, 2006 08:39 AM
jdm95eg
14
Aug 20, 2005 06:01 PM
93WhiteHatch
Apr 26, 2005 07:55 AM
