car wont hold idle on cold start
Old Apr 23, 2007 | 04:07 PM
mjrino's Avatar
Default car wont hold idle on cold start
well im pretty sure its the iacv.. the car started fine and idles fine... but, My car doesnt seem to hold the idle once its rev'd coming from cold start. So i pulled the iacv cleaned it out and now it wont hold any idle at all. should i replace the iacv
which ones are interchangeable???
Old Apr 23, 2007 | 07:22 PM
mjrino's Avatar
anyone
Old Apr 24, 2007 | 05:48 AM
mjrino's Avatar
no help for a noob a researched on symptoms of a bad iacv but im not sure it fits my problem. voltage read about 10v...
Old May 3, 2007 | 08:49 AM
mjrino's Avatar
Default Re: (mjrino)
alright swapped out iacv car runs fine.... but still has trouble holding idel at cold start???
Old May 3, 2007 | 08:51 AM
97Ej6mike's Avatar
IACs for pretty much all D series that use the standard manifold ( excluding D16 Y7 and Automatic JDM D15B's) use a standard two-bolt design. Im currently using a d15b7's on my Z6 manifold, which is on my JDM D15b.
Old May 16, 2007 | 04:28 PM
mjrino's Avatar
ive tried 3 different ic and no solution still
Ericjergs
Nov 16, 2018 07:06 AM
Vspronk
May 2, 2016 08:59 PM
CRX_nut
11
Jan 21, 2010 10:32 AM
See Are X
Mar 24, 2004 06:09 PM
b16vteccx
Mar 22, 2002 06:16 AM
