running a z6 with y8 accessories
Old Apr 23, 2007 | 11:00 AM
Forty04's Avatar
Default running a z6 with y8 accessories
Heres the deal, I've got a d16z6 in my 99 Civic. The z6 I bought did not come with an alternator, or a p.s. pump/bracket/etc, so I had to use the y8 stuff. Problem is, the pulleys on the y8 alt and ps do not line up with the z6 crank pulley
So, we used the y8 crank pulley, on which the timing marks are different thana z6, and I now am unable to set my timing correctly.
My questions are as follows
1 - Is there an aftermarket z6 crank pulley that comes out far enough to accomodate the belts, and still have the correct timing marks?
2 - Has anyone else ever ran this setup (or something like it) and have a possible solution for me?
Thanks in advance
Old Apr 23, 2007 | 11:11 AM
Forty04's Avatar
Default Re: running a z6 with y8 accessories (Forty04)
Upon further research I've figured out that aftermarket Crank Pulley is probably not the way to go
Old Apr 23, 2007 | 12:22 PM
Eibach95Civic's Avatar
Community Builder
i went to honda and got a crank pulley for $65. If that helps any.
Old Apr 23, 2007 | 12:27 PM
pythoner's Avatar
its off by a few degrees, either get z6 parts or fid out how many degrees and accomidate
Old Apr 24, 2007 | 05:44 AM
Forty04's Avatar
Default Re: (pythoner)
I was told that there are OBD conflict issues for the z6 alt and ps, any truth to that?
Old Apr 24, 2007 | 05:49 AM
sicones's Avatar
Default Re: (Forty04)
heres the deal with the PS:
https://honda-tech.com/zerothread/1822781
alt, I think has a different plug
did you try setting the timing with the Z6 pulley??
Old Apr 24, 2007 | 06:48 AM
Forty04's Avatar
Default Re: (sicones)
No I haven't yet. I need to pick up an impact or a big *** breaker bar so I can get the crank pulley bolt off.... and money is tight
Jimster480
Feb 13, 2017 04:51 PM
91integraLSVTEC
Mar 28, 2008 05:52 PM
b20accord
Aug 18, 2007 06:44 PM
HiProfile
Oct 10, 2006 06:19 PM
R4charlie
Mar 21, 2004 08:46 PM
