ran turbo car in rain with no filter. now it sounds funny
Old Apr 23, 2007 | 06:08 AM
lv6l's Avatar
Default ran turbo car in rain with no filter. now it sounds funny
94 civic cx with d16a. t3/t4 turbo. front mount intercool. turbo is running with no filter or screen. there is a plastic piece that covers where the ac radiator should be and of course i have a radiator so water is supposly be block from entering the engine cabin. it was fine until couple days ago i drove it to school on a raining day and now when i drive it it makes a noise. it sound like the motor is louder but deeper in tone. its hard to explain. that is the best i can describe it. what do you guys think it is. water got in motor and now causing noise or water got in my turbine and now making noise.
Old Apr 23, 2007 | 07:50 AM
Jay_Sensing's Avatar
I doubt it man, the odds of water making it into the motor just because it was raining and slim to none. About the only way would be submerging it. I have never been able to run filters on my turbo cars do to size and placement and never had a single problem and most of them were daily driven
Old Apr 23, 2007 | 01:02 PM
lv6l's Avatar
oh then what do you think it could be?
Old Apr 23, 2007 | 01:07 PM
kaiba's Avatar
Default Re: (lv6l)
When it make that sound do you laugh.
Old Apr 23, 2007 | 01:24 PM
lv6l's Avatar
no. and what kind of an answer is that?
Old Apr 23, 2007 | 01:28 PM
kaiba's Avatar
Default Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l &raquo;</TD></TR><TR><TD CLASS="quote">no.</TD></TR></TABLE>
Then it's not funny.
Old Apr 23, 2007 | 01:36 PM
GSaura's Avatar
Default Re: (lv6l)
It's very unlikely that any water got into your motor or turbine and is still there making noise. Check to make sure that nothing cracked when cold water hit your hot manifold and other components. You might have an exhaust leak. Worth a look anyway.
Old Apr 23, 2007 | 01:43 PM
97Ej6mike's Avatar
Most likely does not have to do with water at all.
Are you running a cat? Its not uncommon for the insides of a cat to disintegrate and blow out over time, leaving it entirely hollow, like a test pipe. Also check to make sure you dont have any leaks in ur exhaust, bad gaskets, ect. That could be your problem.
Old Apr 23, 2007 | 09:36 PM
lv6l's Avatar
alright thanks guys. i will check for any leaks. and no i am no running a cat. but if any water DO get into my motor or turbo then leaving it there for a few days in hot heat will naturally dry it up right?
Old Apr 23, 2007 | 09:39 PM
1995Civic's Avatar
Default Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l &raquo;</TD></TR><TR><TD CLASS="quote">alright thanks guys. i will check for any leaks. and no i am no running a cat. but if any water DO get into my motor or turbo then leaving it there for a few days in hot heat will naturally dry it up right?</TD></TR></TABLE>
If you get water into your motor, you're fucked....royally.
Old Apr 23, 2007 | 10:26 PM
Fallen86's Avatar
Default Re: (1995Civic)
its rather hard to get all the way to your motor man, even if it goes thru the turbine, the intercooler naturally traps it there. u might wanna open up your piping if you're so unsure tho...
Old Apr 25, 2007 | 05:30 AM
97Ej6mike's Avatar
Yea, water isnt going to linger around in the motor, its either you hit a puddle and sucked up water, and your royally screwed, or your fine and theres no water, theres no inbetween.
Old Apr 25, 2007 | 05:43 AM
monicle's Avatar
Default Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">Yea, water isnt going to linger around in the motor, its either you hit a puddle and sucked up water, and your royally screwed, or your fine and theres no water, theres no inbetween.</TD></TR></TABLE>
sure there is. he could have water in the low spots on his charge piping. If he restricts the air/charge passage then it could change the feel and sound of the motor a bit.
Old Apr 25, 2007 | 05:52 AM
92redhatch's Avatar
A little bit of water is fine. But if you hit a puddle and suck up a ton of water and hydrolock your motor than your screwed. But in this case there is nothing wrong. Yes over time water does evaporate. It should evaporate in less than a minute. Now i dont think water got into the intercooler piping but over a day or 2 water in the intercooler piping should also evaporate. (well atleast in MIAMI)
Old Apr 25, 2007 | 06:26 AM
andre809_lude's Avatar
Default Re: (92redhatch)
driven on some dirt roads lately dirty highways??? dust.. dirt... it adds up ... Filter!!!
Old Apr 25, 2007 | 09:16 AM
97Ej6mike's Avatar
Default Re: (andre809_lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andre809_lude &raquo;</TD></TR><TR><TD CLASS="quote">driven on some dirt roads lately dirty highways??? dust.. dirt... it adds up ... Filter!!! </TD></TR></TABLE>
He's claiming it soudns deeper and louder, im not too sure that would cause it to sound louder, but rather quieter, the same way an aftermarket intake makes a car's motor sound deeper and louder, than its stock intake does.
Old Apr 25, 2007 | 09:39 AM
STI champstar's Avatar
still don't know why you'd run a turbo with no filter. but louder and deeper tone would only suggest somethings up with intake and exhaust. Maybe you got a leak or crack in your turbo manifold or somewhere on the downpipe....exhaust system. etc.
Old Apr 25, 2007 | 09:40 AM
Default Re: (STI champstar)
and I mean intake as in your intercooler, piping, etc.
lambertincorp
Jan 3, 2007 09:30 PM
ek9child
Jan 19, 2006 03:51 PM
92hatchattack
Apr 25, 2005 03:40 AM
servion
Dec 30, 2003 09:13 AM
freeplay
Aug 22, 2003 04:08 AM
