b16 into eg question
hi guys im so stoooopid, was wondering if any one has carried out a b16a conversion into a 95 eg4 lsi civic, ive got the motor in but now its come to the wiring. i have put in a b16a1 which has been converted to obd1 but have been told my car is obd0 and after removing the ecu, it is. my car had the d15b2 non vtec motor in it, most of the wiring has hooked up apart from one connector on the passenger side strut tower. is there any links to show me how to completely wire me car up?
this is the culprit, if any one can help me out, id be so grateful
Get a 92-95 ex/si wire harness and everything should be there. You will need a p30 ecu or a chipped ecu. then you will need to run O2 sensor wires from ecu out.
If there has been "prewiring" then you are on your own. Get a manual with wiring diagrahms.
Thats why I buy my cars from little old ladies that don't play with the wiring.
lo funnily enough it did come from a little old man who lives round the corner, i havent touched any thing with reguards to wiring, all iv done is lpug in the connectors which would meet up, v got a p30 ecu, i think i need a obd wiring conversion harness. just need to know how to wire up the vtec etc, and also what to do with the plug above which wont plug in.
