Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Spark Plug System
Old Apr 22, 2007 | 09:22 PM
20strong's Avatar
Default Spark Plug System
Does anyone have any experiance with this system?
http://www.nology.com/hot.html
They claim that it produces a spark that is 300 tmes hotter.
Old Apr 22, 2007 | 09:28 PM
faster Type R's Avatar
bump...for some info on this product
Old Apr 22, 2007 | 11:08 PM
20strong's Avatar
One of the guys that i work with runs them on his passat. He dynoed it before and after I guess and he said he gained 15 WHP!
Old Apr 23, 2007 | 05:54 AM
huevosrancheros's Avatar
Default Re: Spark Plug System (20strong)
GARBAGE!!!
Old Apr 23, 2007 | 06:29 AM
eL's Avatar
eL
Default Re: (20strong)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20strong &raquo;</TD></TR><TR><TD CLASS="quote">One of the guys that i work with runs them on his passat. He dynoed it before and after I guess and he said he gained 15 WHP!</TD></TR></TABLE>
Was he also trying to sell it to you?
If wires provided gains of 15whp, more than and intake and exhaust combined... don't you think people would be buying those instead?
There would be a lot less "wHiCh iNtAkE/ExHaUsT sHouLd I GeTz f0' mAh nEw CiViC" threads.
Old Apr 23, 2007 | 07:48 AM
Kiwibird83's Avatar
Reigning GDD Queen
Default Re: (eL)
Nothing but snake oil BS, I got this from an old tech article discussing these crappy ricer wires not to long ago.
The most notable of exaggerated claims for ignition wires are made by Nology, a manufacturer of ignition wires promoted as "the only spark plug wires with built-in capacitor." Nology's "HotWires" (called "Plasma Leads" in the UK) consist of unsuppressed solid metal or spiral conductor ignition wires over which braided metal sleeves are partially fitted. The braided metal sleeves are grounded via straps formed from part of the braiding. Insulating covers are fitted over the braided metal sleeves. These wires are well constructed. For whatever reason, Nology specifies that non-resistor spark plugs need to be used with their "HotWires." In a demonstration, the use of resistor plugs with "HotWires" will nullify the visual effect of the brighter spark.
Ignition wires with grounded braided metal sleeves over the cable have come and gone all over the world for (at least) the last 30 years, and similar wires were used over 20 years ago by a few car makers to solve cross-firing problems on early fuel injected engines and RFI problems on fiberglass bodied cars — only to find other problems were created. The recent Circle Track Magazine (USA, May, 1996 issue) test showed Nology "HotWires" produced no additional horsepower (the test actually showed a 10 horsepower decrease when compared to stock carbon conductor wires).
The perceived effect a brighter spark, conducted by an ignition wire, encased or partially encased in a braided metal sleeve (shield) grounded to the engine, jumping across a huge free-air gap (which bears no relationship to the spark needed to fire the variable air/fuel mixture under pressure in a combustion chamber) is continually being re-discovered and cleverly demonstrated by marketers who convince themselves there's monetary value in such a bright spark, and all sorts of wild, completely un-provable claims are made for this phenomena.
Like many in the past, Nology cleverly demonstrates a brighter free-air spark containing useless flash-over created by the crude "capacitor" (effect) of this style of wire. In reality, the bright spark has no more useful energy to fire a variable compressed air/fuel mixture than the clean spark you would see in a similar demonstration using any good carbon conductor wire. What is happening in such a demonstration is the coil output is being unnecessarily boosted to additionally supply spark energy that is induced (and wasted) into the grounded braided metal sleeve around the ignition wire's jacket. To test the validity of this statement, ask the Nology demonstrator to disconnect the ground strap and observe just how much energy is sparking to ground.
Claims by Nology of their "HotWires" creating sparks that are "300 times more powerful," reaching temperatures of "100,000 to 150,000 degrees F" (more than enough to melt spark plug electrodes), spark durations of "4 billionths of a second" (spark duration is controlled by the ignition system itself) and currents of "1,000 amperes" magically evolving in "capacitors" allegedly "built-in" to the ignition wires are as ridiculous as the data and the depiction of sparks in photographs used in advertising material and the price asked for these wires! Most stock ignition primaries are regulated to 6 amperes and the most powerful race ignition to no more than 40 amperes at 12,000 RPM.
It is common knowledge amongst automotive electrical engineers that it is unwise to use ignition wires fitted with grounded braided metal sleeves fitted over ignition cable jackets on an automobile engine. This type of ignition wires forces its cable jackets to become an unsuitable dielectric for a crude capacitor (effect) between the conductor and the braided metal sleeves. While the wires function normally when first fitted, the cable jackets soon break down as a dielectric, and progressively more spark energy is induced from the conductors (though the cable jackets) into the grounded metal sleeves, causing the ignition coil to unnecessarily output more energy to fire both the spark plug gaps and the additional energy lost via the braided metal sleeves. Often this situation leads to ignition coil and control unit overload failures. It should be noted that it is dangerous to use this style of wires if not grounded to the engine with grounding straps, as the outside of the braided cables will be alive with thousands of volts wanting to ground-out to anything (or anybody) nearby.
Unless you are prepared to accept poorly suppressed ignition wires that fail sooner than any other type of ignition wires and stretch your ignition system to the limit, and have an engine with no electronic management system and/or exhaust emission controls, it's best not to be influenced by the exaggerated claims, and some vested-interest journalists', resellers' and installers' perception an engine has more power after Nology wires are fitted. Often, after replacing deteriorated wires, any new ignition wires make an engine run better.
Old Apr 23, 2007 | 07:52 AM
IT GUY's Avatar
Default Re: (eL)
The fundamental idea of a capacitive ignition charge is not a bad one. I've never seen a car without a distributor use them, but apparantly they are available for them now. From my understanding there seems to be more of a torque increase than a hp increase due to the fact that the caps have less time to charge the faster the motor is spinning. Not sure if this is really the case, correct me if I'm wrong. Didn't Spoon have a similar product for the b-series? or were those just spark plug wires with ground wires on them?
Old Apr 23, 2007 | 07:54 AM
IT GUY's Avatar
Default Re: (IT GUY)
nevermind... lol
Old Apr 23, 2007 | 05:26 PM
20strong's Avatar
Hey thanks for the good read. I should have shoved a bit od sarcasm behind that HP claim he gave me. I dont believe it would give you 15 HP but a hotter spark can be benificial to HP and TQ can it not? &lt;--This question is of topic being as that I am no longer interested at all in the Nology wires thanks Kiwibird83.
kixcrx
Aug 28, 2007 11:38 AM
classciv
Apr 6, 2006 03:28 PM
mountaindewguy
44
Mar 10, 2005 11:36 PM
RACEPAK
Oct 25, 2004 07:04 AM
B00ST2nR
Dec 14, 2003 02:03 PM
