Harness-To-Cage Mounting?
Old Apr 22, 2007 | 07:40 PM
a1320addict's Avatar
Default Harness-To-Cage Mounting?
Figured this would be the best place to post this.
I'm looking into a Simpson or Takata 5-Point Harness setup, and wanted to inquire how you guys went ahead and mounted the harnesses to your roll-cage's harness bar?
I really don't want to modify the cage at all, would rather do the wrap-around securing of the shoulder harnesses. The Simpson and Takata both seem to use either bolt-in or clip-in style mounting for all the belts in the harness.
For the two lap belts, and crotch belt, I'm planning on doing a re-inforced eye-bolt for each, with the clip-in style mounting.
Thanks guys
Old Apr 22, 2007 | 07:45 PM
miller's Avatar
Default Re: Harness-To-Cage Mounting? (a1320addict)
this is something that whoever did your cage should have asked you, depending on the type of harness you use you will need different type's of brackets.
Also the takata harness isnt legal.
Old Apr 23, 2007 | 04:31 AM
Default Re: Harness-To-Cage Mounting? (miller)
Ok, so Simpson it is. Anyone with any input?
Old Apr 23, 2007 | 04:47 AM
miller's Avatar
is the simpson you want to use a single strap or dual?
Old Apr 23, 2007 | 05:02 AM
Edit -
Found the correct-style harness I need, Summit had the wrong description with the picture.
Old Apr 23, 2007 | 05:05 AM
tepid1's Avatar
If you do the wrap around style you need a hoop that will keep the harness from sliding around.
I prefer the bolt in type myself.
Old Apr 23, 2007 | 05:59 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Harness-To-Cage Mounting? (tepid1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 &raquo;</TD></TR><TR><TD CLASS="quote">If you do the wrap around style you need a hoop that will keep the harness from sliding around.
I prefer the bolt in type myself.</TD></TR></TABLE>
as do i:
Old Apr 23, 2007 | 06:32 AM
tepid1's Avatar
Default Re: Harness-To-Cage Mounting? (boostedcivicsir)
Exactly how I did mine....
I was explaining it to Joel in a PM, but that picture is better than a 1000 words.
Old Apr 23, 2007 | 06:46 AM
Mr. Badwrench
i dont like the wrap around, when my cage was done, i asked that it be this way.
Old Apr 23, 2007 | 06:47 AM
Any reason against the wrap-around?
Thanks guys for the help so far
Old Apr 23, 2007 | 06:52 AM
Mr. Badwrench
i havent found a real reason not to like, i have always had bolt in, i know it works, so thats good enough for me.
the main thing about the wrap around, is having a means for it to not be able to slide. last year i dont know how many people at e-town got flagged for not having "stops" their fix was intercooler silicone and hose clamps. i kid you not.
Old Apr 23, 2007 | 06:59 AM
tony1's Avatar
I prefer the wrap around, just put the proper loop around it, no big deal.
Old Apr 23, 2007 | 07:03 AM
miller's Avatar
Default Re: Harness-To-Cage Mounting? (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">I prefer the wrap around, just put the proper loop around it, no big deal. </TD></TR></TABLE>
me too, personally i like the 2 strap wrap around style.
Old Apr 23, 2007 | 07:41 AM
FTP racing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">
me too, personally i like the 2 strap wrap around style. </TD></TR></TABLE>
it works great the wrap around....
Old Apr 23, 2007 | 11:05 AM
Big Teggie's Avatar
Default Re: Harness-To-Cage Mounting? (finaltouchpro)
I have mine wrapped around. I just used some 3/16 rod and shaped it accordingly.
The lap belts I mounted to tabs I placed on the floor. One tab is on plate for the main hoop and the other I used a 4x4 plate for. I used grade 8 bolts too.
Here is how it looks.
Old Apr 23, 2007 | 06:06 PM
matt k's Avatar
Default Re: Harness-To-Cage Mounting? (Big Teggie)
the wrap around is no longer legal from what i saw in tech this weekend i welded a tab on mine before i had my chassis cert Friday i like the wrap around to but changed it because i was told to. the tech gave a Friend **** about his but let him where his reg seat belt
Old Apr 23, 2007 | 06:41 PM
tony1's Avatar
Default Re: Harness-To-Cage Mounting? (bob menuts)
WTF tech inspectors do you keep going to? lol
Old Apr 23, 2007 | 06:51 PM
six sigma racing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">WTF tech inspectors do you keep going to? lol </TD></TR></TABLE>
haha.. be nice tony...
Old Apr 23, 2007 | 06:53 PM
Default Re: Harness-To-Cage Mounting? (Six Sigma Racing)
I didn't see anything about the wrap-around not being legal anymore, does anyone have any more info on this?
Old Apr 24, 2007 | 02:32 AM
tepid1's Avatar
You have to understand Tony.... the tech inspectors here on the East Coast are a lot different from anywhere else. I agree that they should follow the rule book to a "T", but they don't. They all interperet the rules slightly different.
Old Apr 24, 2007 | 06:30 AM
tony1's Avatar
The rules say "seatbelts may not be wrapped around lower framerails" - Section 16 10:5 2007 NHRA Rulebook - General Regulations.
Old Apr 24, 2007 | 06:37 AM
miller's Avatar
I dont know, im on the east coast and never have an issue like some other's do with d-bars and seat belts.
Old Apr 24, 2007 | 07:47 AM
Big Teggie's Avatar
I read the rule book over a dozen times and didnt see any part where you cant use a wrap around mounting style. I havent been to the track yet with my car, but I will be disappointed if they are not legal.
I have seen some of the most unsafe things pass tech at Englishtown.
Old Apr 24, 2007 | 07:51 AM
miller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Teggie &raquo;</TD></TR><TR><TD CLASS="quote">I read the rule book over a dozen times and didnt see any part where you cant use a wrap around mounting style. I havent been to the track yet with my car, but I will be disappointed if they are not legal.
I have seen some of the most unsafe things pass tech at Englishtown. </TD></TR></TABLE>
The wrap around harness is legal.
but i will tell you that e-town has gotten alot more strict with the rules as of late. You have to have a valid drivers license and i have seen cases of them checking the license in the lanes to make sure the driver is the same person who tech'd the car in.
Old Apr 24, 2007 | 05:34 PM
matt k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">WTF tech inspectors do you keep going to? lol </TD></TR></TABLE>you tell me i have never had this much of a problem it seems to be the local nhra track people/techs any where else ive never had a problem
