seat pan swap questions
Old Apr 22, 2007 | 10:17 AM
e jay one's Avatar
Default seat pan swap questions
first of all will it work on del sol seats? and second i put the del sols in there with one bolt to feel them and they sit a little higher then the crx seats. so if i swap pans will they sit low like the stock crx seats?
Old Apr 22, 2007 | 03:16 PM
JDMegCoupe's Avatar
Nope they'll seat higher..so if your short like me 5'2'' it'll be a good swap otherwise nope..just recently got done swaping a set of 96 civic seats..I'm happy with it....
Old Apr 22, 2007 | 09:09 PM
e jay one's Avatar
Default Re: (JDMegCoupe)
thanks but i just talked to someone else on here that actually swapped del sols in with crx pans and he says they sit just a tad lower then stock crx seats.
Old Apr 25, 2007 | 12:03 PM
e jay one's Avatar
Default Re: (e jay one)
just put them in yesterday. not too much work but well worht it. they sit just a little bit lower then stock crx seats and feel way better then stocks.
Old Apr 25, 2007 | 01:04 PM
WrongBeach's Avatar
Very good to know, i'm going to be doing this soon, since my seats are thrashed.
Old Apr 25, 2007 | 01:20 PM
KingDanOne's Avatar
Default Re: (WrongBeach)
yeah im thinking of doing the same to my ef9 seats... will it work the same way??? <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one &raquo;</TD></TR><TR><TD CLASS="quote">just put them in yesterday. not too much work but well worht it. they sit just a little bit lower then stock crx seats and feel way better then stocks.</TD></TR></TABLE> did you take off the 2 bottom bolts and the allen key or did you take off the bolts on the upper part off??? just want to know whats easier i seen two different threads with picture and it seems like taking off the 2 bottom bolts and the allen key bolt cause less damage to the seat...
Old Apr 25, 2007 | 01:24 PM
KingDanOne's Avatar
Default Re: (KingDanOne)
here are the 2 different threads i seen
jap junkies https://honda-tech.com/zerothread?id=1062869
mekanism's https://honda-tech.com/zerothread?id=1288351
it looks that the way jap junkie did it, you damage the seat less????
how did you do it??
Old Apr 25, 2007 | 01:30 PM
89efDUSTY's Avatar
he already got them and he said they feel great...
Old Apr 25, 2007 | 01:32 PM
KingDanOne's Avatar
Default Re: (89efDUSTY)
yeah, im not asking him if he has them buddy , im asking him which way he did it
Old Apr 25, 2007 | 01:46 PM
89efDUSTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one &raquo;</TD></TR><TR><TD CLASS="quote">thanks but i just talked to someone else on here that actually swapped del sols in with crx pans and he says they sit just a tad lower then stock crx seats.</TD></TR></TABLE>thats me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KingDanOne &raquo;</TD></TR><TR><TD CLASS="quote">yeah, im not asking him if he has them buddy, </TD></TR></TABLE> that is the way he did it, i hate dumb remarks you can look for the post where i told him about it...no need to repeat it <U>buddy </U>
Old Apr 25, 2007 | 01:57 PM
89efDUSTY's Avatar
I hate to be an ***...
This is for KingDanOne
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote">on my rex its fits well and is comfy...swap out the seat pans; please dont just drill holes because sheet metal doesnt hold well if you get in an accident. The heighth is ok it feels about the same as the SI seats... Make sure that when you put them in you shave the plastic piece on the side because the floor has grooves and it wont slide. Also tap some holes into the arm where it meets the seat pan, use the correct fastners...dang i should have done a write up on this because this question comes up like every month or so, and people just half *** it...but i know if i get in a crash i wont fly out the window...PM me if you need more info</TD></TR></TABLE>
Old Apr 25, 2007 | 02:44 PM
KingDanOne's Avatar
this is for the *** named 89efdusty - if its not in this thread how the hell am i suppose to know you told him??? you wrote it in a different thread, somewhere else..... and again you expletive all i asked is which way he did it, so read clearly what i wrote, which way did you do it, not explain to me step by step what you did.... its like a mulitple choice question a or b... so go expletive yourself *******!!!!!!
Old Apr 25, 2007 | 02:50 PM
89efDUSTY's Avatar
I did not read how did he do it in your first post because I am @ work and i have to open little windows in the corner... I just thought you had a smart *** comment so i wrote back with one then noticed what you truely said so i wrote it for you...
Never heard of Dane Cook...yah hes gay but whatever...
I am sorry if you felt that "this is for King DanOne" was offensive, but i just put it was for you to so you can read it and not to jack his thread, some people get mad too easy...buddy sorry if you felt hurt
Old Apr 25, 2007 | 08:54 PM
KingDanOne's Avatar
no prob man, i got heated cause i felt like i did nothing wrong, just simply asking which way, but its okay.....
Old Apr 25, 2007 | 09:00 PM
firme ef8's Avatar
kinda of topic..... has anyone ever put ef9 seats in a rex? just wondering how they sit? higher or lower than stock. any pics. thanx
Old Apr 27, 2007 | 09:11 PM
e jay one's Avatar
Default Re: (firme ef8)
man i forgot about this thread. anywase how i did it. i used the whole recliner mechanism off the del sol seat it is bolted to the top part of the seat with 2 14mm and runs along the side of the bottom part of the seat. as far as attaching that to the crx seat on the crx seat pan there is 2 holes where the stock recliner thing bolts to the pan well on the del sol recliner thing one hole is there and i took the crx recliner and ligned it up with the del sol recliner and drilled the second hole. now the del sol recliner thing bolts to the crx seat pan. there is no allens anywhere on either seat. only problem i had was the del sol top part is narrower then the crx pan so it was a little dificult bolting the top to the bottom. and i used zip ties instead of hog rings.
Old Apr 27, 2007 | 09:12 PM
e jay one's Avatar
oh and there is an old thread somewhere where 89efdusty did it i dont know if we did it the same but i used his instructions to get an idea. and this was done in a 88 crx.
antballs420
Oct 31, 2009 05:28 AM
Davidss
Jun 6, 2009 11:11 AM
Mft62485
Jul 10, 2008 08:39 PM
bobalee
Dec 5, 2007 06:44 AM
Shelton
Sep 28, 2004 04:02 PM
