Can't figure out this wiring crx b18a1 swap.
Old Apr 22, 2007 | 08:10 AM
birdricer's Avatar
Default Can't figure out this wiring crx b18a1 swap.
anyone?
Old Apr 22, 2007 | 08:11 AM
nelsmar's Avatar
use yoru factory harness. looks like your tryng to plug obd1 plugs into obd0 harness? grey = obd1 white = obd0. either swap the plugs or swap the harness. :D
Old Apr 22, 2007 | 08:41 AM
birdricer's Avatar
Default Re: (nelsmar)
So if this motor is OBD1 does that mean it's from a 94+ teg?
Old Apr 22, 2007 | 09:08 AM
birdricer's Avatar
Default Re: Can't figure out this wiring crx b18a1 swap. (birdricer)
can someone just tell me what needs to be done to get this thing running?
Old Apr 22, 2007 | 09:38 AM
birdricer's Avatar
What do I need to modify the OBD1 Integra harness to fit my stock DX harness?
Old Apr 22, 2007 | 10:19 AM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by birdricer &raquo;</TD></TR><TR><TD CLASS="quote">can someone just tell me what needs to be done to get this thing running?</TD></TR></TABLE>
Someone already told you, use the stock factory engine wiring harness, plug it up, add the extra wires that you need to make it work right.
Old Apr 22, 2007 | 10:21 AM
Wes V's Avatar
What you <U>want</U> is to hear somebody tell you to just swap around a couple wires and then motor off into automotive bliss.
What you <U>need</U> to do is to contact the guys at Rywire and tell them what you have. Then follow what they recommend. It may just be an OBD1 to OBD0 loom or a conversion of your existing loom. They do this for a living.
Wes
Old Apr 22, 2007 | 12:21 PM
harmonator84's Avatar
Dude you dont even use half that stuff. Just use your harness from your car!
Old Apr 22, 2007 | 12:26 PM
dr_latino999's Avatar
Default Re: Can't figure out this wiring crx b18a1 swap. (harmonator84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harmonator84 &raquo;</TD></TR><TR><TD CLASS="quote">Dude you dont even use half that stuff. Just use your harness from your car!</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes V &raquo;</TD></TR><TR><TD CLASS="quote">What you <U>want</U> is to hear somebody tell you to just swap around a couple wires and then motor off into automotive bliss.
Wes</TD></TR></TABLE>
Here is what you do:
1) Remove OBD-1 Engine Harness
2) Put on OBD-0 Engine harness
3) Wire up stock OBD-0 harness for MPFI
4) Convert OBD-0 MPFI --&gt; OBD-1 MPFI with a jumper
ORRRRR
1) Leave OBD-1 Engine Harness
2) Spend the next year of your life trying to match it up to the shock tower
Old Apr 22, 2007 | 12:31 PM
birdricer's Avatar
Default Re: Can't figure out this wiring crx b18a1 swap. (RCautoworks)
Cant.. NOTHING plugs up.. NOTHING is even close to plugging up
Old Apr 22, 2007 | 12:34 PM
birdricer's Avatar
I emailed the guys at rywire. Hoping they have a conversion loom
Old Apr 22, 2007 | 12:40 PM
89hatcher's Avatar
dude you have to convert your car to multi point first before you would have your b18 running. you have to use some of the clips form your obd1 harness like the distributor clips, and thats about it i think and you would need a obd1 conversion harness. try using this link it will help you a lot.
http://fourthgenhatch.net/mpfi.html
Old Apr 22, 2007 | 01:26 PM
rewerbcrx's Avatar
wow... guy... if you have a DX then you have to convert your originall harness to dpfi (dual point fuel injection) and then use that harness to plug and play with your b18a1 swap... if you are using the wire harness from the engine its a no go. you need the wire harness that goes with the car (NOT THE ENGINE) or you could convert to obd1 now... and AGAIN consult with rywire they are awesome
Old Apr 22, 2007 | 02:17 PM
birdricer's Avatar
Default Re: Can't figure out this wiring crx b18a1 swap. (rewerbcrx)
Yeah, I shot rywire an email. The only reason i'm not splicing wires right now for the MPFI, is because I dont have the correct ECU. and all of the write ups i've found for MPFI are for using PM6, PG7 or PM7 ecus. and from what i've heard.. I need a PR4 ECU for the B18a1 motor.
Old Apr 22, 2007 | 02:24 PM
abnaasefmb's Avatar
ug
Old Apr 22, 2007 | 02:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by birdricer &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, I shot rywire an email. The only reason i'm not splicing wires right now for the MPFI, is because I dont have the correct ECU. and all of the write ups i've found for MPFI are for using PM6, PG7 or PM7 ecus. and from what i've heard.. I need a PR4 ECU for the B18a1 motor.</TD></TR></TABLE> Knock knock
Who's there?
Common sense
LET ME IN!!
My failed attempt at funny, anyways, the Pin outs are the same
Old Apr 22, 2007 | 02:32 PM
birdricer's Avatar
Default Re: Can't figure out this wiring crx b18a1 swap. (dr_latino999)
awesome thanks
Old Apr 22, 2007 | 02:40 PM
civicsi_guy's Avatar
You should check the boomslang web site http://www.boomslang.com I think and look for the install instructions they have all the pins and wire colors where you need to modify it tells you how to change dpfi to mpfi and how to wire up the dizzy I suggest getting a jumper from them cause they have an extra harness that hooks up all the extra things that your harness don't have so there's no repinning at the ecu. Hope that helps
Old Apr 22, 2007 | 04:53 PM
Default Re: Can't figure out this wiring crx b18a1 swap. (civicsi_guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> Knock knock
Who's there?
Common sense
LET ME IN!!
My failed attempt at funny, anyways, the Pin outs are the same </TD></TR></TABLE>
lol..it made me laugh
Old Apr 22, 2007 | 06:34 PM
abnaasefmb's Avatar
lol..it made me laugh</TD></TR></TABLE>
this thread made me cry
jtwellner
Mar 29, 2010 04:16 PM
MidShipCivic
28
Sep 19, 2007 10:01 PM
kbouchard1092
Jan 15, 2007 06:41 PM
RussHondaCRX
Oct 19, 2006 08:39 AM
cccya
Jul 17, 2004 11:21 AM
