main relay
Old Apr 21, 2007 | 02:29 PM
innes887's Avatar
Default main relay
can i use a rz0068 main relay on my 89 crx dx when it came with a rz0063.
Old Apr 22, 2007 | 01:46 AM
innes887's Avatar
unless someone wants to swap for a crx one. i dont know what rz0068 goes to but if you need one i have 2
Old Apr 22, 2007 | 01:33 PM
innes887's Avatar
does anyone know?
Old Apr 22, 2007 | 01:50 PM
Blanket Jackson's Avatar
Just search on car-part.com for one that is correct.
Old Apr 22, 2007 | 02:01 PM
welfarepc's Avatar
Default Re: main relay (innes887)
i tried to interchange them and it didnt work for me. you gotta use the same part number as far as i know.
Dan
Old Apr 22, 2007 | 07:08 PM
innes887's Avatar
do you know if the main relay would stop a starter from cranking, fuel pump from priming, and the right turnsignal light on the dash to illuminate
Old Apr 22, 2007 | 07:20 PM
slowcrxsib16's Avatar
Default Re: (innes887)
sounds exactly like a main relay, i got one from advance for like $55
Old Apr 22, 2007 | 07:40 PM
Make sure you shop around. Don't bother buying used unless it is for a quick fix on a budget.
Old Apr 22, 2007 | 07:47 PM
yeah man, the only thing that sucks about used is this... its used... you dont know if it works or not, best to get it ner
Old Apr 22, 2007 | 09:18 PM
innes887's Avatar
thank you so much guys. ive posted a million threads on if anyone had info about my simptoms. im goin tomorrow to get a relay. thanks again. ill let you know how it goes
Old Apr 22, 2007 | 09:21 PM
harmonator84's Avatar
If you want to go used I have one I will sell you that came out of my Dx.
Old Apr 23, 2007 | 03:24 PM
innes887's Avatar
i just orderd the main relay, but i really dont think thats the problem. when i click my brights when my keys are out of the ignition theres a click coming from the seatbelt thing in the door pannel, the check engine light oil light right turn signal and battery light come on. i think i have a short somewhere
Old Apr 23, 2007 | 03:25 PM
innes887's Avatar
and this is all with the main relay dissconnected
Old Apr 24, 2007 | 09:07 AM
innes887's Avatar
anyone know?
Old Apr 24, 2007 | 09:27 AM
89efDUSTY's Avatar
bad ground?
Old Apr 24, 2007 | 12:25 PM
innes887's Avatar
thats what i was thinking but what ground in some circuit would do this ****?
bigjefft
Apr 22, 2012 12:24 AM
akinas-crx
Nov 11, 2011 08:51 AM
toomspeed
May 7, 2009 11:24 AM
Mr.Smog
Aug 15, 2006 11:13 AM
markvqwerty
Aug 27, 2004 08:52 AM
