how the hell
Old Apr 21, 2007 | 12:03 PM
damn_import_culture's Avatar
Default how the hell
how do you replace your studs what do you need pics please
Old Apr 21, 2007 | 12:04 PM
abnaasefmb's Avatar
Default Re: how the hell (damn_import_culture)
you remove them and put new ones in. if you can be a little more detailed i'm sure people can offer more help.
Old Apr 21, 2007 | 01:44 PM
Default Re: how the hell (abnaasefmb)
i knocked old ones back till they hit dust shield and they stilll arent out th full way like one inch more and old ones out but i cant get dust shield off does whole hub slide off?
Old Apr 21, 2007 | 01:53 PM
91ed9's Avatar
you have to remove the whole hub and get them pressed in
or you can expletive up your **** and hammer them
Old Apr 21, 2007 | 01:54 PM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: how the hell (91ed9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91ed9 &raquo;</TD></TR><TR><TD CLASS="quote">you have to remove the whole hub and get them pressed in
or you can expletive up your **** and hammer them </TD></TR></TABLE>you don't have to press them in you can pull them in with a capless lugnut
Old Apr 21, 2007 | 02:00 PM
Default Re: how the hell (ILcrxsi1)
but how the hell do you get them all the way out
my dust shield wont come off
Old Apr 21, 2007 | 02:38 PM
89efDUSTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by damn_import_culture &raquo;</TD></TR><TR><TD CLASS="quote">but how the hell do you get them all the way out
my dust shield wont come off</TD></TR></TABLE> <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91ed9 &raquo;</TD></TR><TR><TD CLASS="quote">you have to remove the whole hub </TD></TR></TABLE>
Old Apr 21, 2007 | 02:53 PM
RCautoworks's Avatar
Default Re: how the hell (89efDUSTY)
I remember someone doing a write up where you cut the studs a little, but I would never ever do that. Remove the hub
Old Apr 21, 2007 | 03:22 PM
Crx Jimmy's Avatar
Default Re: how the hell (RCautoworks)
grind the back of the studs so they look like a D then they will come out.
Old Apr 21, 2007 | 05:31 PM
91ed9's Avatar
Default Re: how the hell (Crx Jimmy)
omg you people dont listen REMOVE THE HUB and you hit the ******* out
if you dont want to listen to the info being given to you dont post and try to get yout post counts up
Old Apr 21, 2007 | 05:45 PM
abnaasefmb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91ed9 &raquo;</TD></TR><TR><TD CLASS="quote">omg you people dont listen REMOVE THE HUB and you hit the ******* out
if you dont want to listen to the info being given to you dont post and try to get yout post counts up</TD></TR></TABLE>
i gave up after this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by damn_import_culture &raquo;</TD></TR><TR><TD CLASS="quote">i knocked old ones back till they hit dust shield and they stilll arent out th full way like one inch more and old ones out but i cant get dust shield off does whole hub slide off?</TD></TR></TABLE>
Old Apr 27, 2007 | 11:33 AM
my hub wont slide or move but i think it just needs some lube and a good smack
Old Apr 27, 2007 | 11:58 AM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by damn_import_culture &raquo;</TD></TR><TR><TD CLASS="quote">my hub wont slide or move but i think it just needs some lube and a good smack</TD></TR></TABLE> Press ftw?
Old Apr 27, 2007 | 02:08 PM
the1337couch's Avatar
to install the studs take 2 thick washers and the lugs and impact them till they are in no need for a press
Old Apr 27, 2007 | 05:12 PM
91ed9's Avatar
Default Re: (the1337couch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the1337couch &raquo;</TD></TR><TR><TD CLASS="quote">to install the studs take 2 thick washers and the lugs and impact them till they are in no need for a press</TD></TR></TABLE>
and then strip your brand new studs
good info
Old Apr 27, 2007 | 05:15 PM
it doesnt strip them mine went in with no problems. anyway its just another way to do it if you dont have a press.
Old Apr 27, 2007 | 05:23 PM
HondaFerris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by damn_import_culture &raquo;</TD></TR><TR><TD CLASS="quote">wont slide or move but i think it just needs some lube and a good smack</TD></TR></TABLE>
thats kinky
Old Apr 27, 2007 | 05:41 PM
EF_ST@TUS's Avatar
Default Re: how the hell (HondaFerris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFerris &raquo;</TD></TR><TR><TD CLASS="quote">
thats kinky </TD></TR></TABLE>
LOL thats what I thought!
Old Apr 27, 2007 | 06:05 PM
ILcrxsi1's Avatar
Default Re: (91ed9)
good info </TD></TR></TABLE>This won't strip the studs at all. I see the old mechanics at my work do this all the time. I think it works better with an open ended lug nut as I stated above. It just pulls the stud right in.
Old Apr 28, 2007 | 08:34 AM
iluvmyef9's Avatar
Default Re: (ILcrxsi1)
dam just go buy a slide hammer pull the hub go buy a press for a hundreded bucks and press you lug nuts in or if your cheap just barrow a slide hammer pull the hub and hammer them in but you need to prop the hub up a lil so you dont expletive the end of you new lugs up and mushroom the ends
CheeseCake
Jul 13, 2007 06:06 AM
EG2Driver
Jun 6, 2006 08:50 PM
DAguyLS
11
Apr 27, 2004 11:10 AM
GrandMarkie
Sep 5, 2003 08:53 PM
Dr Pooface
Sep 15, 2002 09:38 PM
