99 EK swap question
werd. gots a 99 EK HB and i have a 98 USDM b18c1. i know the driverside mount and cast iron mount has to be changed, but will the trans and other mounts bolt in as well? or just go all 99 civic Si mounts becuase you cant go wrong? also, will the stock GSR axles and wireing harness work? or will i need the 99 SI axles and harness? thanks to al that help me.
You need a 99 si driver side mount(under cam sprockets, bolted to motor), 99 si rear tranny mount, del sol vtec A/C bracket passanger front tranny mount and the rest are stock.
Yes, really. You dont need the delsol a/c mount unless you want to keep or a/c, if you even have it. You will also want to use the 99-00 si harness, gsr will not work. You will have to add the iab sensor plug to the harness and a secondary o2 if you run an obd2 ecu. But that is easier than adding sensors and modifying your stock harness.
using the del slow bracket allows you to retain your factory ac compressor, the gsr or si bracket will require a matching compressor and hoses for a/c, but dont be a pansy FUGGA ac...
wouldnt it be easier to just modify your stock harness instead of taking out your old one and putting an entire new one in?
Yeah if your going to retain your old civic ac then use Del SLow Ac bracket P54 the civic si bracket is the p30 and that will not work, also the integra bracket is the P72 and will not work either. Trust me I am in the middle of doing this myself and i have a 96 civic w/99 gsr...and i have had all ac brackets p54 is the only one that lined up to the bolt holes on the motor.
edit*ohh mine is also a usdm motor*
edit #2 * and taking out a harness is supa dupa easy, in 15 min or less*
[Modified by TheRedSkoolingBus, 10:18 AM 5/29/2002]
[Modified by TheRedSkoolingBus, 10:19 AM 5/29/2002]
Correct me if I'm wrong, but the correct A/C mount would be 94-95 obd1 del sol. I attempted to use a 96 obd2 A/C mount from del sol and did not fit. Note: it was the same as 99 00 si.
i have an ex harness so i should pull that oput and put the gsr harness in?
i heard its easier to just add 3 wires
U would have to use the 94-95 del sol dohc ac bracket to retain ac with the civic ac compressor, if you are going to change out the compressor to an integra compressor, you can use the ac bracket from the b18 motor but you will need to redo your ac lines.
yeah. some dood up there was talking about pullin wireing harnesses through the firewall and crazy stuff like that. i have a mugen chipped p28 with the skunk2 obdII to OBDI jumper harness. i was under the impression that other than the mounts, all ill need is the 99 Si engine wireing harness("that strings along the motor"),, not the harness from the ECU to the engine harness. anyhow, if i get that(99 Si engine harness), thats all ill need right? WTF... BTW screw A/c 54 extra pounds i dont need, i even removed my windshield washer box and smoothed out the body where my rear winshield wiper was,, which was removed. ALSO 99 and 00 EK hB's are different than 96-98's. so for those other than me, read really closely, so you dont F-up down the road when you didnt realize there was a difference.
other than that, thanks for those that somewhat came close to answering my original question.
later
later
Homericaeast
May 7, 2002 11:21 AM
