mpfi question
Old Apr 21, 2007 | 08:28 AM
alexsracing's Avatar
Default mpfi question
i changed a 88 civic 4door to mpfi and i did all the wiring right but when i turn the car on cylinder 1 i don't think is getting gas... so basicaly its running on three cylinders could this just be the injector?
Old Apr 21, 2007 | 08:32 AM
SIred91's Avatar
Rainman
Default Re: mpfi question (alexsracing)
Yes, it could be, but it also could be the wiring.
Old Apr 21, 2007 | 09:37 AM
Foxcow's Avatar
Default Re: mpfi question (SIred91)
Can you move one injector from one cylinder to another to test that theory?
Old Apr 21, 2007 | 09:46 AM
SIred91's Avatar
Rainman
Default Re: mpfi question (Foxcow)
so how do you know what cyls are getting gas or not to begin with?
Old Apr 21, 2007 | 10:15 AM
i have already moved the wiring but cylinder one still nothing
and it has spark i have already checked that also
Old Apr 21, 2007 | 12:11 PM
janz3n's Avatar
Default Re: (alexsracing)
could be the wiring but could be the injector doesnt work anymore.
by moving the wiring what do you mean? try what foxcow said take out two injectors and moved them around and see if it still wont work.. if so then you probably need a new injector.
Old Apr 21, 2007 | 12:21 PM
4g hatch's Avatar
pull the plug out and see if it smells like gas and looks wet. if not i would bet a bad wire somewhere. trie to find a injector test light that you can borrow.
Old Apr 21, 2007 | 02:19 PM
janz3n's Avatar
Default Re: (4g hatch)
or just put a screw driver agains it and put your ear to the handle.. think you should hear clicking noises .
1spoiledbrat
Oct 1, 2012 03:20 PM
InvaderTrax
May 4, 2008 01:57 PM
98vtec
12
Feb 12, 2008 03:30 PM
BIG RICH
Sep 16, 2006 11:55 AM
my91civic
Jul 6, 2003 06:13 PM
