Alignment issue
Well i got my car back from the alignment shop and my steering got better but my camber wear is still bad? i drove about 300miles now and took my tires off and they're wasted. I called the shop and i told them did they adjust my camber kit to zero out the toe and the owner said they charge extra to adjust the camber kit and he said that to zero out the toe is not good? I don't know if he's Bullshitting me but i've read that having zero toe would give less camber wear? my car is lowered on coilover and i dropped it until my tires are perpendicular to my finders leaving only my fender being able to tuck under my fender. Can i still get a zero toe and be good?
zero toe is bad. should always have atleast some. would go with factory toe specs, and not to be an *** but most shops wont adjust camber dut to the time consumption of it. even though they told you they did. the do what i call a toe and go.
time is money
time is money
