cant get hose off thermostat housing.....HELP!!
Old Apr 19, 2007 | 12:01 PM
floatfisher's Avatar
Default cant get hose off thermostat housing.....HELP!!
any suggestions?? the hose will not budg at all
im trying to do this as we speak!
thanks
Old Apr 19, 2007 | 12:57 PM
Dave_B's Avatar
Default Re: cant get hose off thermostat housing.....HELP!! (floatfisher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by floatfisher &raquo;</TD></TR><TR><TD CLASS="quote">any suggestions?? the hose will not budg at all
thanks</TD></TR></TABLE>
My suggestion is get a large pair of pliers. Grab around the area where the inlet is and hose is covering. Twist the hose around a bit (may have to "bite" in different areas to loosen up the corrosion) after you get it to twist, you should be able to get it off.
HTH.
Old Apr 19, 2007 | 01:03 PM
walker111's Avatar
Default Re: cant get hose off thermostat housing.....HELP!! (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">
HTH.</TD></TR></TABLE>
x2 or cut it and buy new hoses.
Old Apr 19, 2007 | 01:35 PM
Arsenal's Avatar
Default Re: cant get hose off thermostat housing.....HELP!! (walker111)
Get a razor blade and cut a diagonal line from the end about 1" down, you can then pry the end up and voila! its off.
Old Apr 19, 2007 | 01:38 PM
neo_'s Avatar
Default Re: cant get hose off thermostat housing.....HELP!! (Arsenal)
As what Dave_B said.
Old Apr 19, 2007 | 02:38 PM
money is really tight right now and didnt want to buy a new hose....wouldnt pliers rip the hose though??
if i put a small 1" slice in it....would i still be able to use the hose?
Old Apr 19, 2007 | 02:48 PM
neo_'s Avatar
Try sticking a flat head screw driver in between the thermostat housing and the hose, wiggle it around and insert it all around the hose. That breaks it loose too.
Old Apr 19, 2007 | 04:50 PM
Default Re: cant get hose off thermostat housing.....HELP!! (neo_)
thanks neo i will try that tomorrow
Old Apr 19, 2007 | 05:07 PM
Echo7847's Avatar
From the sound of it you're trying to get @ the thermostat or something of that nature. Just remove the 2 10's that hold the housing together and take it with the hose if you want to preserve it.
Old Apr 19, 2007 | 09:36 PM
hayabusa160's Avatar
Default Re: cant get hose off thermostat housing.....HELP!! (Echo7847)
spraying wd40 helps sometimes. usually slides right off once it soaks in.
Old Apr 20, 2007 | 07:12 AM
whitelightning's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by floatfisher &raquo;</TD></TR><TR><TD CLASS="quote">money is really tight right now and didnt want to buy a new hose....wouldnt pliers rip the hose though??
if i put a small 1" slice in it....would i still be able to use the hose?</TD></TR></TABLE>
put a rag over the hose then use the pliers.
Old Apr 20, 2007 | 08:57 AM
rcar97's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 &raquo;</TD></TR><TR><TD CLASS="quote">From the sound of it you're trying to get @ the thermostat or something of that nature. Just remove the 2 10's that hold the housing together and take it with the hose if you want to preserve it.</TD></TR></TABLE> What he said, and don't scratch the housing surface, it may leak afterwards. You might want to change to a worm gear clamp if it leaks.
Old Apr 20, 2007 | 08:32 PM
thanks to all of ur suggestions.....i ended up just removing the thermostat housing with the hose attached. although it was tight, i still managed to reach in and grab the defective thermostat.
in the end, my car was running at normal temps again with no problems. i was a happy guy for the rest of the day
obuhmyuh
Feb 25, 2008 04:54 PM
Tizight
Nov 19, 2006 02:25 PM
bertyman
Sep 26, 2005 12:24 PM
B16Civic93
Mar 3, 2005 05:15 PM
ragejed
Aug 12, 2003 07:06 PM
