d16 block guard
Old Apr 19, 2007 | 11:09 AM
Vt3c_eg's Avatar
Default d16 block guard
im building up my block and was wondering if these block guard are good. are these the new design that will not overheat? anyone use these before? its kms blockguard.
http://cgi.ebay.com/ebaymotors...ZWDVW
Old Apr 19, 2007 | 11:21 AM
THC07's Avatar
Default Re: d16 block guard (Vt3c_eg)
what are you building?
open or closed decks do not effect cooloing or make any hotspots.
EDIT: Open deck ftw
Old Apr 19, 2007 | 11:23 AM
Vt3c_eg's Avatar
building my d16z6 block with vitara pistons and eagle rods. useing block guard. and boosting.
Old Apr 19, 2007 | 11:26 AM
THC07's Avatar
oh, how much boost? 15+ ??
Old Apr 19, 2007 | 11:35 AM
dohcdelsol's Avatar
Default Re: d16 block guard (THC07)
to be honest with you, ive done several d series blocks with keeping the stock sleeves. but when it comes time for new sleeves or doing a block guard, i would personally take it to a builder.
check up with earl or golden eagle. if you do some research, you will see that they do damn great work.
Old Apr 19, 2007 | 12:27 PM
Vt3c_eg's Avatar
Default Re: d16 block guard (dohcdelsol)
yes 15+.
Old Apr 19, 2007 | 12:28 PM
Vt3c_eg's Avatar
yes 15+.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol &raquo;</TD></TR><TR><TD CLASS="quote">to be honest with you, ive done several d series blocks with keeping the stock sleeves. but when it comes time for new sleeves or doing a block guard, i would personally take it to a builder.
check up with earl or golden eagle. if you do some research, you will see that they do damn great work.</TD></TR></TABLE>
so you think stock sleeve will do the job?at least 300whp.
Old Apr 19, 2007 | 01:20 PM
dohcdelsol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt3c_eg &raquo;</TD></TR><TR><TD CLASS="quote">yes 15+.
so you think stock sleeve will do the job?at least 300whp.</TD></TR></TABLE>
all depends on the tune and condition of the stock sleeves. right now the motor im building is stock sleeves bored .020 and shooting for 300whp. no block guard.
ive seen d series handle 400whp on stock sleeves (pink car) but like i said, the tune has a big affect on it.
Old Apr 19, 2007 | 04:12 PM
Vt3c_eg's Avatar
yeah. i think ill still get the block gaurd just to make sure. you're right it depend on the tuning too! thanks for your advice.
Old Apr 19, 2007 | 04:27 PM
Shaun_'s Avatar
Full race d series build for pinks ran 30+ psi on stock d sleeves.
Old Apr 19, 2007 | 07:06 PM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt3c_eg &raquo;</TD></TR><TR><TD CLASS="quote">yeah. i think ill still get the block gaurd just to make sure. you're right it depend on the tuning too! thanks for your advice.</TD></TR></TABLE>
Honestly...if you're building for 300whp no need to sleeve the block.
A block guard is alright, however its not necessary. It only supports the top of the sleeve, and still can leave the bottom prone to cracking.
Like I said though, you should def be alright without it. Just have the block checked out at a machine shop, and find out if the cylinders are out of round. If they are, you will need to have it re-bored.
If you do go with a BG, get a Golden Eagle.
Old Apr 19, 2007 | 07:59 PM
Vt3c_eg's Avatar
Default Re: d16 block guard (1995Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Civic &raquo;</TD></TR><TR><TD CLASS="quote">
If you do go with a BG, get a Golden Eagle. </TD></TR></TABLE>
so golden eagle you think is better!? how about kms? which is better?
Old Apr 19, 2007 | 08:03 PM
1995Civic's Avatar
so golden eagle you think is better!? how about kms? which is better?</TD></TR></TABLE>
Golden Eagle. Their cooling is far superior.
Like I said though, Im not a big believer in BG's. I think the idea for them is right, however as i stated before, it doesnt do anything to provide protection for the bottom of the cylinders.
Old Apr 19, 2007 | 08:43 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt3c_eg &raquo;</TD></TR><TR><TD CLASS="quote">building my d16z6 block with vitara pistons and eagle rods. useing block guard. and boosting.</TD></TR></TABLE>
All those nice, high end, name brand parts, and you're gonna pair it with a POS ebay block guard?
Not what i would do, but it's your engine.
Old Apr 19, 2007 | 08:50 PM
Vt3c_eg's Avatar
Default Re: d16 block guard (Syndacate)
its kms. im going to get it from either kms or golden eagle. there not cheap ebay stuff.
Old Apr 19, 2007 | 08:54 PM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt3c_eg &raquo;</TD></TR><TR><TD CLASS="quote">its kms. im going to get it from either kms or golden eagle. there not cheap ebay stuff.</TD></TR></TABLE>
I would still go for GE if anything.
Im still standing by what I said about how you dont need it.
Do you know to truely install it correctly?
Old Apr 19, 2007 | 08:57 PM
Vt3c_eg's Avatar
Do you know to truely install it correctly?</TD></TR></TABLE>
since you said that i think ill go with golden eagle. no i dont know how to install it.do you know or know a link to how to install block gaurd.
Old Apr 19, 2007 | 09:07 PM
1995Civic's Avatar
since you said that i think ill go with golden eagle. no i dont know how to install it.do you know or know a link to how to install block gaurd. </TD></TR></TABLE>
Heres some info on why you dont need one...listen to Rota92. Hes my bud, hes a D series Guru
http://www.turbod16.com/viewto...stall
Old Apr 19, 2007 | 09:25 PM
Vt3c_eg's Avatar
http://www.turbod16.com/viewto...stall</TD></TR></TABLE>
thank you! so i guess i dont need bg.i guess i can run stock sleeves and still be good! thats sweet. save me 100+ bucks.
Old Apr 19, 2007 | 09:37 PM
1995Civic's Avatar
thank you! so i guess i dont need bg.i guess i can run stock sleeves and still be good! thats sweet. save me 100+ bucks. </TD></TR></TABLE>
For sure man.
Thats why we're here!
Good luck with everything.
Old Jan 22, 2010 | 08:42 AM
ballisticej1's Avatar
I'm trying for 300+whp or so, not more than 350ish on stock sleeves with 76mm vitaras. No block guard.
K20teggg95
Nov 4, 2011 06:44 AM
GoneToTheDarkSide
Mar 19, 2010 05:48 PM
SiRay13
Aug 26, 2006 02:22 PM
marksturboek
Apr 23, 2006 03:02 PM
miller
Dec 16, 2003 02:30 PM
