best place to buy a thermostat for 00 Si
i am looking to replace my Thermostat in my 00 Si bc the car doesnt seem to want to heat up and i was wondering whats the best place to buy a new thermostat + gasket would be ? Should i go to Autozone, Advance Auto, O'Reilly Auto or the Dealer ?
Re: best place to buy a thermostat for 00 Si
Yeah advance auto, autozone will have it. But when I have bought one there it never comes with the rubber gasket that goes around the thermostat. I had to use my old one, which was in good shape so it was ok.
You can always run to your local Honda Dealer and order it and make sure you get the gasket to if you need it. If your gasket is good you can get the advance T-Stat and just swap over the gasket.
When re-installing make sure you put the little bleed hole at the 12 oclock position.
LUiS010606
03-19-2009 10:09 AM
