BFG 215/60/14 Drag Radial, post your exp. lowest tire press?
Old Apr 19, 2007 | 06:06 AM
g2turbo's Avatar
Default BFG 215/60/14 Drag Radial, post your exp. lowest tire press?
Id like to know your experiences if you have run on this tire or a similar version.
Power level, boost level, launch rpm
How low can you take the pressure on these? Ect.. Thanks for reading
Old Apr 19, 2007 | 06:27 AM
0554's Avatar
i have the 225/50/15's and run them at 10psi and cut consistant 1.8's and a few 1.7's
Old Apr 19, 2007 | 06:46 AM
g2turbo's Avatar
Default Re: (0554)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0554 &raquo;</TD></TR><TR><TD CLASS="quote">i have the 225/50/15's and run them at 10psi and cut consistant 1.8's and a few 1.7's </TD></TR></TABLE>
Cool, thats what I was looking for. What power level? Turbo car?
Old Apr 19, 2007 | 04:33 PM
0554's Avatar
yes turbo gsr prolly right around 300ish
Old Apr 20, 2007 | 07:41 PM
g2turbo's Avatar
Default Re: (0554)
my car went 12.037 tonight with about 12 psi tire pressure
BFG 215/60/14
2.0X sixty foot. I really need gear based boost! I definitely think the last pass would have been a 11.9 or so but I couldnt run again. I had to pedal the car in 2nd but was still falling way out of power into 3rd gear. Little more practice would be good.
1st pass-13.2@120
2nd pass- 12.55@127
3rd pass- 12.22@125
4th pass-12.03@127
Old Apr 20, 2007 | 07:45 PM
DaveF's Avatar
Default Re: (g2turbo)
i dont know if that is the same size tire i had back in 00 but i belive it is... i cut 1.8 60ft with no traction bars @ 12 psi tire pressure. ya have to get the tires super hot to make them worth a damn though. i got a shiton of milage/street racing on those.
Old Apr 20, 2007 | 09:31 PM
OnlyHJC's Avatar
Default Re: (dturbocivic)
wow those are some good times
Old Apr 21, 2007 | 05:03 AM
blackeg's Avatar
Default Re: (OnlyHJC)
i go down to 10 psi in my bfg's.
Old Apr 21, 2007 | 09:08 AM
g2turbo's Avatar
Default Re: (blackeg)
we did start at 10 but after the burnout the tires go back up to around 12
Old Apr 21, 2007 | 10:02 AM
xtrafastcivic's Avatar
i found no difference on my all motor car from 12-20 psi.... on 15's tho ...
Old Apr 21, 2007 | 06:33 PM
OnlyHJC's Avatar
Default Re: (xtrafastcivic)
one thing iknow for sure is that the bfg's love long burnouts.
Old Apr 21, 2007 | 10:44 PM
sohc_turd's Avatar
I just picked up a set of 215/60/14 BFGs, was supposed to test them out today but the track got rained out.
I like the fact that this size has a 5" sidewall, and i don't know for sure yet but i'm hoping that the extra sidewall will have less deflection than the other lower profile BFGs ive ran in the past when launching hard.
Old Apr 22, 2007 | 05:57 PM
g2turbo's Avatar
Default Re: (sohc_turd)
my 12.22 pass
you can see the car fall all the way out of power from 2-3 lol. The next pass was 12.03@127
http://youtube.com/watch?v=GDXGkkdr3hQ
I want to change the limiter from ign. cut to fuel cut as well. I dont like the popping.
Old Apr 22, 2007 | 06:29 PM
sohc_turd's Avatar
just curious what rpms are you launching at?
Old Apr 22, 2007 | 09:18 PM
JST1CAM's Avatar
I am borrowing some 215/60-14s from my buddy and I think they are a lil big. Atleast for street racing cuz they rub a lil. I def.had to much air last night.
I have a turbo d15b on 8psi. We ran 20psi in the tires and the hooked up like ****. Felt faster on street tires. might go toaround 12 psi and try a longer burnout and see what happens. My ebrake sucks so i mightjust have to bring a gallon ofwater.
Old Apr 22, 2007 | 09:28 PM
sohc_turd's Avatar
Default Re: (JST1CAM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JST1CAM &raquo;</TD></TR><TR><TD CLASS="quote">I am borrowing some 215/60-14s from my buddy and I think they are a lil big. Atleast for street racing cuz they rub a lil. I def.had to much air last night.
I have a turbo d15b on 8psi. We ran 20psi in the tires and the hooked up like ****. Felt faster on street tires. might go toaround 12 psi and try a longer burnout and see what happens. My ebrake sucks so i mightjust have to bring a gallon ofwater.</TD></TR></TABLE>
They are 24" tall so at sub 200whp, its probably gonna really feel slow. I havn't dyno'd the new setup but at 25psi on race gas tune the 215/60/14s grip decent for street duty.
Old Apr 22, 2007 | 09:49 PM
GetawayInMoscow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2turbo &raquo;</TD></TR><TR><TD CLASS="quote">my 12.22 pass
I want to change the limiter from ign. cut to fuel cut as well. I dont like the popping.</TD></TR></TABLE>
You probably wont build any boost off the line then
Old Apr 23, 2007 | 04:09 AM
g2turbo's Avatar
Default Re: (GetawayInMoscow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow &raquo;</TD></TR><TR><TD CLASS="quote">
You probably wont build any boost off the line then</TD></TR></TABLE>
I wasnt using any kind of 2 step or antilag on these passes. We are gonna set all of that up in the next few weeks.
Changing the rev-limiter from ignition to fuel cut should be independent of how the antilag works... I think.
Old Apr 23, 2007 | 07:44 AM
sohc_turd's Avatar
Depending on what system you are using, but you should be able to build at least 5psi off the line.
Old Apr 25, 2007 | 06:06 AM
g2turbo's Avatar
12.037 pass at 127 mph
http://www.youtube.com/watch?v=QGKPgImt03k
I was trying to pedal the car and let out a little too much in 1st lol.
Old Apr 25, 2007 | 07:12 AM
Innes's Avatar
great passes
i love '94-95 white si hatchbacks....
Old Apr 25, 2007 | 08:49 AM
slywfbpsi's Avatar
Default Re: (Innes)
the site says 6" wheel width. But, will they work on 5.5?
Old Feb 28, 2013 | 04:50 PM
johnie1199's Avatar
10 Year Member
Default Re: BFG 215/60/14 Drag Radial, post your exp. lowest tire press?
i dont think so min is 6-7.5 205 and 6-8 for the 225
Steeve_Civic
Sep 14, 2014 11:24 PM
Orangeciv
Aug 15, 2008 08:46 PM
B00STED Si
Mar 11, 2005 04:16 PM
b18cTurbo
Jul 27, 2003 10:45 AM
01PYTypeR#1140
May 16, 2002 07:33 AM
