how to hook up oil pressure gauge?
" If it is a mechanical gauge, the hose has to be t'd between the block and oil pressure sender.
If it is an electric gauge, you need to install the pressure sender that came with the kit between the block and stock oil pressure sender.
The oil pressure sender is right above the oil filter to the left. You will need to get under the car to do anything with it since it is directly under the manifold. "
hope this helps
hope this helps
heres what you need. http://tunertoys.zoovy.com/product/OTODK
screen name is tuner toys, you can pm him also.
n0pinitr0us
21
Apr 10, 2005 08:55 PM
