what should idle be with iacv unplugged?
Old Apr 18, 2007 | 10:36 PM
the.hamburglar's Avatar
Default what should idle be with iacv unplugged?
about 500 or what? i need an exact number thanks
Old Apr 19, 2007 | 09:43 AM
Default Re: what should idle be with iacv unplugged? (the.hamburglar)
ttt
Old Apr 19, 2007 | 09:46 AM
EG2Driver's Avatar
there is no exact number...its going to be all over the place because it controls the amount of air leaking in the intake manifold, keeping the RPMs in check with how warm the engine is.
Old Apr 19, 2007 | 10:03 AM
Relic1's Avatar
according to the idle set procedure in the Helms... 400 RPM.
This is for most OBD1 cars, OBD2 is slightly different depending on which engine/ECU you have.
Old Apr 19, 2007 | 11:19 AM
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">according to the idle set procedure in the Helms... 400 RPM.
This is for most OBD1 cars, OBD2 is slightly different depending on which engine/ECU you have.</TD></TR></TABLE>
thanks, that sounds about right.
MonkeyMagic
May 4, 2008 02:30 PM
ej2civic
Oct 3, 2007 09:51 AM
pork
Sep 24, 2007 09:46 AM
StinkyTofu
Apr 6, 2003 09:31 AM
