NEED TO KNOW IF MY RC550 IS SATURATED OR PEAK N HOLD
From: riCk jAmes BitCh 415 fRisKo 2 cAstRo yAy aREa, CA, usa
sup ht
i have rc550 injectors and iono if i need to run a resistor box
anybody know how to tell the difference if the injector is saturated or peak n hold
is there a # dif
is there another way to find out besides using a test light??
thanks ht
is there a # dif
thanks ht
What are the numbers on the injector? A saturated injector would say SL9-550. Saturated does not require a injecotr box. Peak and hold you need a resistor box. Hope this helps!
thanks
whoops, i prob didnt make it out
i knew if its saturated you dont need a resistor box, i was wondering if there was anyway to tell if the injectors were peak n hold by their serial number on the injectors
THANKS ALOT DUDE , YOUR HELP IS VERY APPRECIATED
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral »</TD></TR><TR><TD CLASS="quote">Measure the resistance across them with an ohm meter.</TD></TR></TABLE>
2-3 ohm, p&H need resistor box
12 -13 ohm, saturated no box needed.
skeetahendo
Mar 15, 2008 03:44 AM
