Is it possible to test compression on a d16a6 while it is out of the car?
Old Apr 18, 2007 | 02:21 PM
DropSide's Avatar
Default Is it possible to test compression on a d16a6 while it is out of the car?
recently picked up a stock motor and want to check the compression before installing it. Is there any way to do this while the motor is out of the car??? What about a leak down test??? LMK thanks
-Chris
Old Apr 18, 2007 | 02:25 PM
dohc_profile's Avatar
WHO THE
Old Apr 18, 2007 | 02:44 PM
ALLMOTOR CRX's Avatar
yes take out the spark plug and instert the compression tester and get the 19mm socket and the ratchet and turn the crank pulley bolt.. like if it was running dont stop keep on doing it until the needle from the compression tester will stop and wont go up any more....
Old Apr 18, 2007 | 02:46 PM
civhatch90's Avatar
i think i have seen this done at one of those engine importers. they just hot wired a battery to the starter and the engine turned i dont see why it couldnt be done. i dont know about a leak down but you could probably do that one too
Old Apr 18, 2007 | 06:22 PM
DropSide's Avatar
Default Re: Is it possible to test compression on a d16a6 while it is out of the car? (DropSide)
I figured it out and all cylinders tested above 170. You have to run a jumper from a good battery sitting on a peice of wood and ground it to the block and run power to the starter to crank the motor a couple of times. Insert a compression gauge into the cylinder one at a time and you will get a reading. Make sure the flywheels spins all the way around before you do this to make sure the motor is not locked up.
92integraVTECgsr
Mar 17, 2006 10:55 PM
FK00GSR
Apr 14, 2005 06:03 AM
NOSed_b18b
Jan 20, 2003 10:54 AM
JDMEMM
Oct 21, 2002 10:56 PM
JCracer723
Aug 22, 2002 03:17 PM
