Crank Position Sensor, Crank Fluctuator Sensor
Old Apr 18, 2007 | 04:12 AM
twinj's Avatar
Default Crank Position Sensor, Crank Fluctuator Sensor
Does anyone know if any of those sensor are in the B16 oil pump. Different people call it different things but i heard it is the samething.
Old Apr 18, 2007 | 04:15 AM
Jay_Sensing's Avatar
It's not in the oil pump, it's a magnetic pickup behind the crank pulley and the metal sprocket it picks it's reading from is on the front of the timing belt sprocket.
Old Apr 18, 2007 | 04:18 AM
twinj's Avatar
oh, ok thanks^^
Old Apr 18, 2007 | 05:06 AM
Luserkid's Avatar
Default Re: (twinj)
Crank position is in the Dist. and the crank fluc. is the sensor on the oil pan for obd2.
Old Apr 18, 2007 | 05:59 AM
JDMFantasy2k's Avatar
Default Re: (Luserkid)
it's actually bolted to the oil pump there guy
from what i understand, the CKF sensor will send the same signal as the CKP sensor and then it looks for a difference between them or something like that.
Old Apr 18, 2007 | 06:09 AM
twinj's Avatar
Where is it on the Oil pan i want to check to see if there is one. Far as the Dis is concern how could i check that. The car has an OBD2A setup so would it automaticly throw a CEL.
Old Apr 18, 2007 | 06:33 AM
EE_Chris's Avatar
Default Re: (twinj)
Oil PUMP...not pan. Look at your oil pump - do you see a sensor with some wires hanging off of it? If yes, that's the CKF because there's never been another sensor mounted on the oil pump.
Old Apr 18, 2007 | 06:57 AM
twinj's Avatar
My bad: yea pump i don't know what the expletive i was looking at. I am not that mechanically (sp)inclined
Old Apr 18, 2007 | 08:50 AM
DumpedSi's Avatar
Default Re: (twinj)
are you replacing yours or whats the problem? Its a bitch to get to if you dont have air tools.. the oil pump is behind the crank pulley and lower timing belt cover which is hell to get off if you dont have the right tools...
Old Apr 19, 2007 | 07:10 AM
twinj's Avatar
just got a JDM b16a and trying to convert everything to the obd2 b16 model
Old Apr 19, 2007 | 07:18 AM
D16Z6_turbo's Avatar
Default Re: (twinj)
http://rywire.com/store/faqdes...8ce8a
you can try this for an easy fix...
tnxx
Dec 7, 2009 05:43 PM
schlong1
Oct 19, 2008 05:38 PM
warwagon
Jan 11, 2005 05:14 PM
bluesi00
Jun 2, 2004 11:35 AM
