PROBLEM WITH A B18 GSR SWAP INTO MY EG6 HELP!!!!
Old Apr 17, 2007 | 05:50 PM
DJNauTicz's Avatar
Default PROBLEM WITH A B18 GSR SWAP INTO MY EG6 HELP!!!!
i just done a swap to my EG6 with a b18C GSR
problem..1) when i drive on 1st gear my car shake's when i press GAS
once i hit 2000RPM shake a bit.then is fine..after.and whenva i switch gear it shake's...that's the first problem..
2) problem..when i rev.car stoke like go stop go stop...for some reason..
right now i'm using a P28 ECU..
please help me with this problem..
if u need me to explain more details i'll do so
Old Apr 17, 2007 | 05:52 PM
1.8L_allmotormilitia's Avatar
shaking could be axle(s) ?
p28 ecu virgin isn't a good idea to run for a very long time.
Old Apr 17, 2007 | 05:54 PM
DJNauTicz's Avatar
Default Re: (1.8L_allmotormilitia)
no not that kind of shake..is like stoking kind of shake..but only go up to 2000rpm
after 2000 run's ok..
Old Apr 17, 2007 | 07:10 PM
JDMBoostedDA's Avatar
your shake is most likely axles. i have a 2002 S10 extreme as well as my car. i've had to replace the driveshaft twice now and it gives a similar shaking. the driveshafts are most likely loose form your swap. try to get the car on a lift or some jack stands and look them over. be sure they are properly placed all the way in their slots and bolted tightly. they are spinning unbalanced and they slowly tighten up and balance out at higher RPMs is your problem.
Old Apr 17, 2007 | 08:27 PM
DJNauTicz's Avatar
Default Re: (JDMBoostedDA)
but is kinda weird...like..slow start shake...and up to 2000 still shake..but anything upper 2000 is good.. and when i rev it stoke's. i might check..but i remember i replace the axle today..i change them over and over..but is the same problem.that's why i dont think is the axle problem could it be my ECU??since i'm usin a P28 instead of a p72???
or can it be something else??please help..thank you
Old Apr 17, 2007 | 08:34 PM
fmrprojects's Avatar
Default Re: (DJNauTicz)
engine mounts are bad espeially the stabilizer mounts on the bottom of the chassis
Old Apr 17, 2007 | 08:59 PM
instrument's Avatar
have you checked your mounts? do you have all five tightened properly? is it five? yeah.
and whats shaking? the engine? the tires? the hood? your ***?
Old Apr 17, 2007 | 09:11 PM
hybridmath's Avatar
Default Re: (instrument)
lol i dont use 5 mounts in my eg i only use the 3 main mounts the other mounts
Old Apr 17, 2007 | 09:12 PM
hybridmath's Avatar
Default Re: (hybridmath)
are not needed and i dont get any vibrations in my car
Old Apr 17, 2007 | 09:52 PM
SCRev's Avatar
if the shake happens in relation to the gas pedal being pressed then its probably motor mounts or something similar. if the shake happens at given rpms or mphs regardless of gas pedal position, then its probably driveline related instead.
Old Apr 18, 2007 | 09:23 AM
DJNauTicz's Avatar
the whole car shake's not just the hood or anything. and whenva i press gas it doesn't seen like wanted to go...that's why
let me check again today..and i'll let you guys know
Old Apr 18, 2007 | 12:05 PM
TNRspeed's Avatar
it sounds to me like one of your sensors might be bad. I use to have a 91 civic with a b16 and it sound you had the same problem i did. to tell you the truth though i never really figured it out, because i sold it. I always thought though that it was the distributor for some reason. Sorry i cant help
csnuggzr6
Dec 21, 2009 03:18 PM
JKov240
Aug 10, 2007 11:42 AM
ID_ten_T
Jan 12, 2004 07:08 PM
NYCz DA9
28
Feb 24, 2003 09:31 PM
