starter issue, doesnt crank
Old Apr 17, 2007 | 05:13 PM
go2sleep's Avatar
Default starter issue, doesnt crank
My starter began to act up. I took it to kragen, bench tested it, and it was fine, gear extends and spins.
I reinstall the starter and all it does it click once. I turn the key again, and it would jsut click once. Maybe after trying it a few times (20 or so tries), it would start. This is a new reman. starter.
Now i'm guessing either the starter relay or the ignition switch needs to be replaced.
battery is fine, starter is new. is this a wiring issue now?
Old Apr 17, 2007 | 09:39 PM
Leung's Avatar
Default Re: starter issue, doesnt crank (go2sleep)
check grounding wire condition
Old May 6, 2007 | 06:49 PM
go2sleep's Avatar
Default Re: starter issue, doesnt crank (Leung)
wires are good. starter just clicks but doenst turn.
seems to always need help from a jump start.
Modified by go2sleep at 8:24 PM 5/6/2007
Old May 6, 2007 | 08:03 PM
hondakevin21's Avatar
Can you get a rachet and socket and turn the engine over by hand? Have you checked your battery?
Old May 6, 2007 | 08:42 PM
del_slow420's Avatar
Default Re: starter issue, doesnt crank (hondakevin21)
u say the battery is fine but after trying to turn it over 20 times im sure that will take a tool on the battery have u tried to jump start it or get the battery tested?
D7KWagon
Aug 8, 2014 02:57 AM
Integra_drk
Dec 27, 2006 10:19 AM
Touge Tuning
May 3, 2006 11:14 AM
DAYUIZ
Jan 20, 2004 03:03 PM
mingchi69
Jul 14, 2003 06:14 PM
