Idling at 2500rpm's constantly!!!! It's a jdm zc
Old Apr 17, 2007 | 03:21 PM
christian7750's Avatar
Default Idling at 2500rpm's constantly!!!! It's a jdm zc
I checked the fitv and replaced the tps. I checked all tubes for vaccum leaks and can't find any. HELP!!!!!
Old Apr 17, 2007 | 03:52 PM
Lord Milferdeen's Avatar
Default Re: Idling at 2500rpm's constantly!!!! It's a jdm zc (christian7750)
perhaps it is an intake manifold gasket leak
Old Apr 17, 2007 | 03:56 PM
93CX's Avatar
Default Re: Idling at 2500rpm's constantly!!!! It's a jdm zc (Lord Milferdeen)
IACV or gasket leak would be my guess.. was it idling well before this started?
Old Apr 17, 2007 | 04:22 PM
Default Re: Idling at 2500rpm's constantly!!!! It's a jdm zc (93CX)
yes, it was idling fine. it just sat for a while
Old Apr 17, 2007 | 07:07 PM
bump
Old Apr 18, 2007 | 10:21 AM
bump
Old Apr 19, 2007 | 09:25 AM
bump
Old Apr 20, 2007 | 11:09 PM
You got it all figured out?
Old Apr 20, 2007 | 11:15 PM
SoHc94's Avatar
high idle can be caused by a few things. check yur dizzy if it is pivoted all the way forward then thats the fastest idle. and then the idler screw on the TB. screwed out is high idle and in is low idle. does it sound like a vacuum leak... like whistling noises?
Old Apr 22, 2007 | 12:09 PM
Default Re: (SoHc94)
well when I closed the iacv the car dies, so doesnt that mean that there is no vacuum leaks?
Old Apr 23, 2007 | 09:30 AM
Default Re: (christian7750)
bump
jmpassey
Jun 7, 2018 02:34 PM
HIallday
Sep 13, 2011 10:34 PM
twentyhurtz
Jan 16, 2009 08:30 AM
bleedblue94
Jan 4, 2006 10:05 AM
Traction
48
Aug 12, 2004 09:57 AM
