The infamous 3rd gear grind and its fix
Old Apr 17, 2007 | 02:59 PM
$amGD3's Avatar
Swaggylicious
Default The infamous 3rd gear grind and its fix
I searched and I only found this
is that the ONLY way to fix it?I mean goddamn,is there a cheaper alternative that will lessen the grind or something?
Old Apr 17, 2007 | 03:10 PM
Archidictus's Avatar
Unceasing Measure
You can try changing your fluid, but if there's damage to the gears themselves or the synchros, you're stuck having to replace one or both. Sucks, but that's how it goes.
It'll be far cheaper to just buy a transmission that doesn't grind
Old Apr 17, 2007 | 03:11 PM
cambopheonix56's Avatar
Default Re: (Archidictus)
Amsoil/gm syncromesh will cover the problem up.
Old Apr 17, 2007 | 04:02 PM
93CX's Avatar
Default Re: (cambopheonix56)
Synchromesh will help if its not too bad.. I tried it, but it was too late. I ended up buying a fresh B16 trans. BTW, when they cracked open my old transmission, third gear was in about 10 peices.. but maybe the fluid will help you.
Old Apr 17, 2007 | 04:08 PM
pdiggitydogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 &raquo;</TD></TR><TR><TD CLASS="quote">Amsoil/gm syncromesh will cover the problem up.</TD></TR></TABLE>
Lets stress that
Old Apr 17, 2007 | 04:20 PM
Boostedb20EH2's Avatar
Default Re: (pdiggitydogg)
Its not going to bother you driving around knowing that your tranny has a part needing replaced and it could go out anytime? I say replace it, dont cover it up with synchromesh.
Old Apr 17, 2007 | 04:25 PM
TNRspeed's Avatar
Default Re: (Boostedb20EH2)
This is the reason i bought a brand new type r trans. I know it was probably cheaper to fix but hey now i got lsd.
Old Apr 17, 2007 | 05:06 PM
yoffer's Avatar
Banned
From what i have heard, that Amsoil is the shizzle nitch! But hell its worth a try.
Old Apr 17, 2007 | 06:12 PM
$amGD3's Avatar
Swaggylicious
Default Re: (TNRspeed)
hmmmm,how many bottles do I need of this syncromesh?
Old Apr 17, 2007 | 07:18 PM
Default Re: (sam21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sam21 &raquo;</TD></TR><TR><TD CLASS="quote">hmmmm,how many bottles do I need of this syncromesh?</TD></TR></TABLE>
3, just do a drain and fill. Only like 2.5 quarts comes out.
Old Apr 17, 2007 | 07:43 PM
EG2Driver's Avatar
3, just do a drain and fill. Only like 2.5 quarts comes out.</TD></TR></TABLE>
2.3liters for a B16 tranny
Old Apr 17, 2007 | 08:15 PM
wrEcKed_LX's Avatar
Default Re: (DeadEnd9009)
Synchromesh didn't help my tranny at all. It still sounds like I have straight-cut gears but I don't have the money to fix it
dan12288
15
Nov 23, 2007 07:31 PM
VTECcnIT
Feb 25, 2006 12:12 PM
dkim48
Honda S2000
Dec 5, 2005 05:20 AM
danny98r
Feb 18, 2004 04:29 PM
shermanyang
Aug 17, 2003 11:05 AM
