*** hondata launch control ***
I have a del sol tuned with hondata s300... and after I had it tuned I was looking at the settings on my computer and the launch control was not tured on...I was just wondering if it was ok to just check the box to turn it on, set the rpm, and set it to the "always on" setting and set the maxspeed to like 2mph or something low like that, the reason im asking is because there is also options to adjust fuel and timming, but do I have to do that or can I just turn it to "always on" and set the rpm and speed to turn off??
also with the full throttle shift can I just turn that on and set the rpm, and set it to "always on"as well...or is there anything special that I would need to do, there is also a check box that says invert input on both the launch control and the full throttle shift do I just leave that unchecked??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 »</TD></TR><TR><TD CLASS="quote">you bumped it less than 30 mins from posting it? lol
a SUPER easy way to find out is to call Hondata up and they can tell ya first hand
yeah I could do that...but there closed...and if someone knew the answers to my ?s it would only take them 2min to type it out
</TD></TR></TABLE>yeah I could do that...but there closed...and if someone knew the answers to my ?s it would only take them 2min to type it out
when I want to chang the rpm level...do I just plug my ecu in and download whats on my ecu to my comp. , then chang the rpm, then upload it back to the ecu?? Is this all I have to do?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BUCK_NASTY »</TD></TR><TR><TD CLASS="quote">when I want to chang the rpm level...do I just plug my ecu in and download whats on my ecu to my comp. , then chang the rpm, then upload it back to the ecu?? Is this all I have to do?</TD></TR></TABLE>
yes. or just save it to your computer and load it off of your hardrive instead of downloading it from the ecu.
also when you put in your rpm's, be sure that your fuel/ignition activate rpm is 200 rpm's less than your launch control rpm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 »</TD></TR><TR><TD CLASS="quote">
also when you put in your rpm's, be sure that your fuel/ignition activate rpm is 200 rpm's less than your launch control rpm.</TD></TR></TABLE>
thanks
thanks
BUCK_NASTY
Apr 20, 2007 08:29 PM
B18PoweredCivic
Apr 2, 2003 03:15 PM
