master cylinder resavoir
ok so i was checking my oil and i noticed burnt fluids (picture soon) or brown stuff on my hood. its from the MC all the way down to my radiator. so curious i opened my master cylinder resavoir and it had a vacum sound to it. and my fluids levels are okay and im just wondering what fluids can sprayed out onto my hood. the inside of it that is. just 2 things im worried about: did i let air into my brake system and wtf is that on my hood.
thanks for the help HT
Start the engine and get it up operating temperature. Do different things like revving the engine, turning the steering wheel from side to side, etc. to see if any fluids starting coming out. (To me, based on the spray pattern, it looks like the it came out near power steering pump area and flowed backed a little.)
I'm very curious to what caused it. Let us know.
That's normal on all DD integras.....its called your drive belts are catching some dirty rain water and spray all over that general area of the hood!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Carbon Fiber »</TD></TR><TR><TD CLASS="quote">That's normal on all DD integras.....its called your drive belts are catching some dirty rain water and spray all over that general area of the hood!!</TD></TR></TABLE>
x2 but you might want to look unde the car also to make sure theres no fluid leaking any where underneath thats getting on the belts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Converted »</TD></TR><TR><TD CLASS="quote">Power steering pump. Probably making a bit of a squealing noise too. I have a spare if you need one.</TD></TR></TABLE>
well my car is making sounds when i turn my steering wheel. so i'll check on my PS hoses.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg »</TD></TR><TR><TD CLASS="quote">And no, you did not add air into your brake system by opening your resevoir.</TD></TR></TABLE>
koo thanks
i'll let you guys know tomorrow when i check things out.
anymore ideas?
koo thanks
anymore ideas?
Jim Pivonka
10
Aug 11, 2014 06:02 PM
Voodoo7
Jan 30, 2012 09:47 PM
97SS
Jan 23, 2008 08:04 PM
