if i swap an h22
Old Apr 17, 2007 | 10:39 AM
ekblack9's Avatar
Default if i swap an h22
well there have to be any inside work done like to make it fit cuz i heard some guy say at a shop but i dont know if it was bs. thanks
Old Apr 17, 2007 | 12:04 PM
Padawan's Avatar
Darth ModerVader
Default Re: if i swap an h22 (ekblack9)
What do you mean by "inside work"?
Old Apr 17, 2007 | 12:44 PM
CivicSpoon's Avatar
There's some cutting involved for the shifter and shifter cables.
Old Apr 18, 2007 | 12:35 PM
ekblack9's Avatar
Default Re: if i swap an h22 (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">What do you mean by "inside work"?</TD></TR></TABLE>
oops wasnt specific. well i mean any cutting like under the hood engine bay area to make the h22 fit or can it fit flush with out cutting?
Old Apr 18, 2007 | 04:10 PM
SiRek4
Guest
Posts: n/a
Default Re: (CivicSpoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSpoon &raquo;</TD></TR><TR><TD CLASS="quote">There's some cutting involved for the shifter and shifter cables.</TD></TR></TABLE>
Old Apr 18, 2007 | 04:25 PM
FerioRallyB16a's Avatar
Default Re: (SiRek4)
i have H22a in CB7(accord), it bolt right in so had no problems doing it
and my friend also did it in eg 2dr
he told me that, except for bit of cuttin/weldin,
it's not that hard since they have H-mount n Axles for civics nowdays
r u gonna use H tranny or B tranny(w/H-B convertion)..?
short ratio B-tranny will def. utilize HP n TQ from H....
n i heard it more funn too..
anyways
i was told that P/S and A/C won't be working(maybe there is way to get by)
can not lower your car too much BC engine is much taller, some case, engine will hit the hood...
BC of that F/R WEight ratio, u need to have stiffer suspension on front...
but i gotta tell u.. if u do it rightway... u gonna have lots of funn
MaaaD torque pumpin h22a in civic w/ IHE will kill most of cars on street...
Old Apr 18, 2007 | 05:39 PM
Hmotorsol's Avatar
i have a h22 in my del sol and im using the hasport mounts and i dont have too much clearance issues the hood is a very snug fit but it still shuts completely and u have to cut the tranny mounts bracket from the frame if u are going to use the h22's tranny.
Old Apr 18, 2007 | 06:24 PM
Default Re: (Hmotorsol)
do u have P/S and A/C in your sol..?
if so how did u manege to keep them w/ h22a swap..?
thank you
Old Apr 19, 2007 | 08:01 AM
ekblack9's Avatar
i already have the stiff suspension and its not lowered too much. i have a carbon fiber hood would i have to get a regular hood if its gonna fit snug
Old Apr 19, 2007 | 08:07 AM
95ProjectEJ1's Avatar
Default Re: (ekblack9)
If you go H2B with the H22 you will have to do a prop or chop of the hood.
Old Apr 19, 2007 | 09:34 AM
H22Ej1's Avatar
Shenanigans
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekblack9 &raquo;</TD></TR><TR><TD CLASS="quote">i have a carbon fiber hood would i have to get a regular hood if its gonna fit snug</TD></TR></TABLE>
i dont see y this would be a problem unless its an aftermarket style
my buddies fits with his aftermarket cf hood...its close but it fits
Old Apr 19, 2007 | 09:35 AM
CivicSpoon's Avatar
oops wasnt specific. well i mean any cutting like under the hood engine bay area to make the h22 fit or can it fit flush with out cutting?</TD></TR></TABLE>
Depends on what mount kit you use.
For HCP you need to trim the passenger side mount bracket and drill the inner hole bigger, like here:
This is to clear the shifter cable attachment points.
For the Hasport kit you need to cut (or drill out the spot welds) of that mount bracket and drill holes to put on the new one. Here's Hasport's instructions: http://www.hasport.com/tech/installs/EGH2.pdf
No clue what any other kit needs you to do, I'd assume they will come with instructions.
Old Apr 19, 2007 | 10:55 AM
NathanMorris's Avatar
Default Re: if i swap an h22 (CivicSpoon)
inside work is limited to cutting two holes in the 'tranny tunnel' or more correctly, the exhaust tunnel. Sawzaw will do this fine. Then route the shifter cables.
Nathan
h22civicsedan
Jun 1, 2008 02:29 PM
CiViC SiR
Apr 9, 2008 04:00 AM
BIGBLOCKEK
Nov 13, 2004 01:16 AM
gdrum
Feb 13, 2004 02:45 PM
