good suspenion kit for h22 ina 94 hatch
Old May 28, 2002 | 12:27 PM
blackhyb's Avatar
Default good suspenion kit for h22 ina 94 hatch
what would any one suggest for an h22 in a civic for suspension
Old May 28, 2002 | 02:10 PM
bretx0r's Avatar
Default Re: good suspenion kit for h22 ina 94 hatch (blackhyb)
high spring rates up front, good shocks and a stiff rear sway bar
Old May 28, 2002 | 08:19 PM
HondaCutter's Avatar
Do the eibach sportline's have a high spring rate?
Old May 28, 2002 | 08:34 PM
JeffS's Avatar
Default Re: good suspenion kit for h22 ina 94 hatch (HondaCutter)
No, Sportlines are on the low end of the scale. An "off the shelf" set of springs isn't going to be well suited to this kind of hybrid.
I would go with something like Ground Control sleeves and choose whatever spring rates you feel are right. Of course, this is dependent on what you're going to use the car for.
The logical thing is to stick high rates in the front... this may actually be making the car handle worse though. With so much weight in the front, it's going to be a tricky setup. A large swaybar seems key. I would start with fairly even spring rates (maybe a little higher in the rear), and a large rear swaybar w/ a smaller one in the front. I'm coming from a track standpoint though.
Old May 28, 2002 | 09:05 PM
VtecDeMoN's Avatar
You might want to try contacting Newman at Newman@JDMshit.com, or Jeff Sloan at jeff@hybridautomotive.com. Both post frequently on the hybrid board and one of Newman's current projects is a H22A EG and Jeff is planning making an H22A track car in the near future. They should both be able to provide some helpful information for you, just make sure that you thank them for anything they can give you.
Brian
Old May 28, 2002 | 10:31 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: good suspenion kit for h22 ina 94 hatch (VTEC CX)
Time to call Truechoice or Advance Design...
Old May 29, 2002 | 05:59 AM
Jason kiDD's Avatar
Default Re: good suspenion kit for h22 ina 94 hatch (SkyeC)
Well I am planning on using Skunk 2 coilovers, AGX struts, ITR Rear Sway bar with lower tie bar front and back, and upper tie bar front and back.. That should be a good place to start..
I will let you know how the setup feels with stock wheels in a week..
hondaguyef
Apr 14, 2004 11:21 AM
superpirate25
May 29, 2003 09:47 AM
sydag5
Mar 12, 2002 04:31 PM
prjctCIVIC
Jan 30, 2002 04:26 AM
