OEM Injector Size in B16?
Old Apr 16, 2007 | 08:54 PM
EX-T's Avatar
Default OEM Injector Size in B16?
Are the oem injectors in a b16 240cc?
Old Apr 16, 2007 | 09:02 PM
Tomdata's Avatar
Default Re: OEM Injector Size in B16? (EX-T)
yes
Old Apr 16, 2007 | 10:24 PM
h2point2's Avatar
what are the stock d16 injectors? i just put a obd0 b16 in my eg6 and used the obd0 injectors, just rewired my harness to use obd0 plugs.
Old Apr 17, 2007 | 12:53 PM
Tomdata's Avatar
Default Re: (h2point2)
you better be careful. the obd0 injectors require a resistor box wired in or they will kill the ecu. I believe the OBD1 D16 injectors are also rated at 240cc.
Old Apr 17, 2007 | 12:56 PM
pdiggitydogg's Avatar
Do NOT use obd0 injectors without a resistor box, as said
If you need injectors I have a set of obd1 that I dont need or want
Old Apr 17, 2007 | 03:15 PM
h2point2's Avatar
if i can use my stock injectors from the d16 that would be awesome. if not yea just let me know on those injectors you have i will pick them up
Old Apr 17, 2007 | 03:18 PM
lsvtecracer's Avatar
you can use the stock 0bd1 d16 injectors. It's the same as the obd1 b16/b18.
Old Apr 17, 2007 | 03:49 PM
peak/hold
vs
saturate
Old Apr 18, 2007 | 11:08 AM
Tomdata's Avatar
Default Re: OEM Injector Size in B16? (Tomdata)
scratch n sniff
Old Apr 18, 2007 | 11:10 AM
fmrprojects's Avatar
use the d16 injectors
jthrasher1
11
Dec 4, 2010 09:48 AM
Ak_ef9
Jul 11, 2006 05:49 PM
the.hamburglar
Mar 11, 2006 06:10 PM
civicefdx
Oct 18, 2004 04:38 PM
