can i put my stock fuel injectors back after wiring in a resistor harness for 450's?
trying to trace a problem with my car? will my car run ok if i put the stock fuel injectors back? i mean will that resistor box interfere at all?
Re: can i put my stock fuel injectors back after wiring in a resistor harness for 450's? (the.hambur
no, you would need to revert back to the stock wiring
depends...you could pput low impedence stock injectors...but you wont be able to put the ones out of your stock motor into them no
so ill need obd 0 injectors? i have 2 sets of obd1 ls injectors at 1 set of obd1 b16 injectors. neither of these will work?
it seems like you are going to do what ever you want. so why even ask us. we told you what you have to do, and you seem that you are going to ask the same questione untill you get the answre you want, even if its not the right one.
so with that in mind, good luck and have fun frying your ecu.
Re: (the.hamburglar)
Just take out the resistor box if you don't want to buy different injectors. It's pretty easy to desolder a couple wires and put it back to stock. Or, if you know someone with an OBD0 car that upgraded their injectors, ask em if you can use their stock ones temporarly. I'd give you my old set if I could find em, but I have no idea where they are, I think I threw them out
You won't fry an ECU putting OBD1 injectors into a car with a resistor box.
You will be running the injectors in an innapropriate way, causing the fuel tables to be totally off (and you to probably be pretty lean in most of the map) because they expect the injector's behavior without the resistor box.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar »</TD></TR><TR><TD CLASS="quote">its like 8 wires id have to desolder. ill just get obd0 injectors and the stock LS ecu</TD></TR></TABLE>I'll take pics tommorow of how I wired my resistor box and injectors. I can take out the resistor box in like 30 seconds, and not have to desolder anything.
