b16 head?
the Type R manifold is nothing more than a B16's with a factory port and polish. They are the same cast. Be careful of what you buy as B18C1 intake manifold (94+ GSR) will not fit on a b16 head, the bolt pattern is different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 »</TD></TR><TR><TD CLASS="quote">the Type R manifold is nothing more than a B16's with a factory port and polish. They are the same cast. Be careful of what you buy as B18C1 intake manifold (94+ GSR) will not fit on a b16 head, the bolt pattern is different.</TD></TR></TABLE>
Actually I think the runners on the P30 manifold are a little different. Not positive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">
Actually I think the runners on the P30 manifold are a little different. Not positive</TD></TR></TABLE>
they are different. The P30 is better for midrange and the P73 has a little shorter runners which makes it better for top end.
Plus the P73 has a smooth top without any markings = pure sex.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 »</TD></TR><TR><TD CLASS="quote">the Type R manifold is nothing more than a B16's with a factory port and polish. They are the same cast. </TD></TR></TABLE>
that only applies to the head. the manifold's are slightly different as said in this post:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sauceja »</TD></TR><TR><TD CLASS="quote">they are different. The P30 is better for midrange and the P73 has a little shorter runners which makes it better for top end.
Plus the P73 has a smooth top without any markings = pure sex.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugencx »</TD></TR><TR><TD CLASS="quote">What about a ls dizzy on a b16a head? will a ls distributor work on a b16a head?</TD></TR></TABLE>
with some modifications
NOman0608
May 4, 2008 06:01 PM
