some questions about charge pipe size on low boost application
Old Apr 16, 2007 | 08:57 AM
Mr.E.G.'s Avatar
Default some questions about charge pipe size on low boost application
I have a 90 miata 1.6 liter with a garret gt2560r running ten lbs of boost.
the charge pipe on this thing is seriously about 1.75 inches wide.
it seems to me that this setup doesnt need huge intercooler piping but what it has seems a bit small. i would imagine that with a little bit bigger piping, maybe 2.5 inches, that the turbo would spool faster.
what do you guys reccomend?
Old Apr 16, 2007 | 02:26 PM
hondapimpin420's Avatar
Default Re: some questions about charge pipe size on low boost application (Mr.E.G.)
i am no expert but the bigger pipe you put on the the more the turbo has to fill up before building boost. thus turbo lag. the smaller it is it may choke the turbo and higher rpm creating HP loss.i have a t 28 with a 48 trim and im puting 2.25 pipe on it if the helps .
Old Apr 16, 2007 | 03:07 PM
esedulerp5tenin's Avatar
Default Re: some questions about charge pipe size on low boost application (hondapimpin420)
larger piping = more lag
10lbs is a pretty decent amount tho, so you could go 2 or 2.25" to get a bit more power, but it'll also increase the lag
Old Apr 16, 2007 | 03:38 PM
Mr.E.G.'s Avatar
ahh. i see.
so whats the verdict? should i go bigger or keep it the same?
Old Apr 18, 2007 | 07:18 AM
Default Re: (Mr.E.G.)
if it was my car i would run 2in pipe to the IC and 2.25 Pip to the TB. but it may in crease lag. you will get more out of your turbo at Higher rpms though.
Old Apr 18, 2007 | 08:41 AM
Mr.E.G.'s Avatar
Default Re: (hondapimpin420)
i guess ill wait until i have it tuned and see whats going on then. if my top end hp isnt what it should be then ill go with some bigger piping. if the top end looks pretty good, then ill probably just leave it alone since this thing is a 1.6 and extra lag would make it even slower. lol.
Old Apr 18, 2007 | 09:46 AM
smart man.
dgaf95integra
Oct 19, 2012 04:57 PM
accord99power
Sep 4, 2009 04:02 AM
JM Performance
Jan 1, 2004 08:02 AM
JeremyL
Nov 12, 2002 05:34 AM
98hx99b18c
Dec 13, 2001 09:18 AM
