charge pipe size
Old Apr 21, 2008 | 01:50 PM
dgaf95integra's Avatar
Default charge pipe size
I searched but did not get a clear answer, What is the diffrence and purpose? Please help out a noob.
Old Apr 21, 2008 | 02:15 PM
Schister66's Avatar
Man U FTW
Its all about gross air flow and resistance in a certain size pipe. If you run a smaller IC pipe, you have less empty space to fill so you reach full boost sooner, BUT you can't flow as much air through it. On the other hand if you run a larger diameter IC pipe, you can push more overall volume through it, but since there is more void to fill, it takes longer to reach full boost.
Old Apr 21, 2008 | 02:45 PM
Root of all Evil's Avatar
for a street car with up to 400whp 2'' is fine.
Old Apr 21, 2008 | 06:41 PM
JoePSI's Avatar
Default Re: (Root of all Evil)
Eh, I think 2'' is a little small, 2.5'' is a lot more suitable imo.
Old Apr 21, 2008 | 08:27 PM
ehe
Old Apr 21, 2008 | 08:58 PM
da_dude's Avatar
2.5" on the cold side and 2" on the hot side of the IC piping.
Old Apr 21, 2008 | 09:09 PM
Turbo-charged's Avatar
Default Re: (da_dude)
i never run anything smaller than 2.5 inch unless it wont psychically fit
Old Oct 19, 2012 | 04:08 AM
boostedteg4dr's Avatar
Default Re: charge pipe size
for a 650hp application with a 6262 .63ar. should i run 3 inch on both sides of ic?
Old Oct 19, 2012 | 04:55 AM
TheShodan's Avatar
Moderator
No. 2.5" for both sides of the Intercooler is just fine.
Old Oct 19, 2012 | 04:57 PM
DelSolMarine's Avatar
I made 670whp at 26psi with 2.5 inch charge piping and a 64mm throttle body...
rdeezy78
Dec 16, 2008 12:02 PM
Boostinb20!
Sep 10, 2008 04:45 AM
Sound Streamin'
Jun 25, 2004 11:14 PM
5thgen
Feb 25, 2004 09:15 PM
