how to tell a type r head from the others
Old Apr 16, 2007 | 07:39 AM
1greatEG's Avatar
Default how to tell a type r head from the others
im buying a 2000 civic si they guy says he has an itr head on how can i tell???
Old Apr 16, 2007 | 07:49 AM
sauceja's Avatar
Default Re: how to tell a type r head from the others (1greatEG)
By the distributor there should be some green paint. This can be washed off if it was ever tanked though.
In between the dizzy and the vtec solenoid it will say 30 but that just means its from the newer casting as in OBDII cars.
The date on the exhaust side of the head in the 4 circles the one closest to the vtec sol. should be 97 or higher and can go all the way up until 07 because they have to keep making parts for cars up until 10 years after the last production year.
Otherwise you will have to look at the combustion chambers and the intake ports to see the hand porting job from the factory.
Other than that there are no surefire ways to tell.
Also the lost motion assembly's are different but that is mainly from the older B-series heads.
Good luck.
Old Apr 16, 2007 | 07:52 AM
EGhatch87's Avatar
look by where the dist bolts to.it will have some green painted on it. (00-01 says PR3-4)
Old Apr 16, 2007 | 07:53 AM
Padawan's Avatar
Darth ModerVader
ITR valve springs should also have blue paint (exhaust side) and yellow paint (intake side).
Old Apr 16, 2007 | 08:09 AM
1greatEG's Avatar
Default Re: how to tell a type r head from the others (Padawan)
thanks u guys will let you know after i pick it up so im juss gonna look for the green paint. thanks guy gonna go pick it up right now
Old Apr 16, 2007 | 10:18 AM
LSR 0NE's Avatar
Duel coil valve springs on both the intake/exhaust valves.
Old Apr 16, 2007 | 10:52 AM
zerovandez's Avatar
don't gsr have dual valve springs too?
Old Apr 16, 2007 | 10:56 AM
LSR 0NE's Avatar
Default Re: (zerovandez)
just on the intake.(correct me if im wrong)
Old Apr 16, 2007 | 03:51 PM
sauceja's Avatar
Default Re: (LSR 0NE)
The bad thing is for 100.00 you can pick up some ITR valvesprings. They aren't that much if you look around.
So that doesn't hold much ground.
Green paint could be applied by anyone as well.
The best way to tell is by the hand port job on the intake ports of the head which would be hard.
Otherwise if the head has been ported but than a B16 head that has been ported is equal or better than a bone stock ITR head.
The combustion chambers are also cleaned up by the factory.
All B16/R heads say PR3-x that doesn't mean squat. Just casting numbers.
hondacando
Jul 31, 2010 03:00 PM
TurboEM1
Dec 26, 2009 07:50 PM
moz92
20
Feb 10, 2007 07:15 PM
92b16vx
Jan 22, 2004 07:28 AM
cyfiro
Apr 28, 2002 06:22 PM
