Oxygen Sensor Heater - CEL
Old Apr 15, 2007 | 08:50 PM
Yellow Submarine's Avatar
Default Oxygen Sensor Heater - CEL
Hi there guys,
Because of a poor after market cat converter install, the 02 sensor at the back of my cat was rubbing up against the underside of the car, and as a result, one of the 4 wires (the black heater element wire) was stripped, blew the alternator fuse (have since replaced the fuse), and rendered the o2 sensor generally unusable.
I have since installed the cat correctly, and replaced the 02 sensor, however, I still have a CEL, ECU code 194, Oxygen Sensor Heater, even after resetting the ECU. There is no voltage going to the 02 sensor on the same black wire. I looked for a fuse for the 02 sensor heater, but cannot find one. Where should I check for a break in the circuit? Thanks so much for all of your help!
Old Apr 18, 2007 | 12:30 PM
Default Re: Oxygen Sensor Heater - CEL (Yellow Submarine)
Anyone?
Old Apr 18, 2007 | 12:44 PM
infulleffect's Avatar
You may have back feed the board and fried it. I say this only because I have seen it before and have had to trace every wire and check for continuity. I even jumped the heater from the front O2 to the rear which got rid of the CEL, but the car never shut off .
So your options basically are:
1) Barrow and ECU from a GSR, ITR, etc. that is OBD2 and will plug up to see if the CEL goes out. If it does and all is well...and that works, then you need another ECU.
2) Get and OBD1 harness and a programed OBD1 ecu from the appropriate cars of course and never worry about the rear O2 again.
I hope this helps.
Cheers
Old Apr 18, 2007 | 12:48 PM
Relic1's Avatar
The ECU grounds the heater, power is delivered though the under dash fuse box.
if you're talking about your '00 then the black/yellow wire runs directly from the under dash fuse box to the O2 heater.
make sure your EVAP bypass solinoid (black/white) and the EVAP canister vent valve (black/yellow) has 12V. If they do then there is a problem with the black/yellow wire leading to the O2 heater.
Old Apr 25, 2007 | 08:09 PM
TurtlePowerCivic's Avatar
Default Re: (Relic1)
Hey Relic, do you know what color the 02 heater wire is that runs into my fuse box? I drive a 98 civic lx-t (D16y7).
Old Apr 26, 2007 | 06:20 AM
Relic1's Avatar
primary - black/yellow - to underdash
secondary - Black/white - to underdash
bandit67
Jun 15, 2011 11:14 AM
rebuiltSI
Jul 24, 2007 09:07 PM
SpoolinEK
May 21, 2004 02:42 PM
6SPD_EK
Feb 20, 2002 03:55 PM
