FS. d15b full swap.500$OBO. (vtec-e.)
* B A N N E D *
the motor has approx 90k miles. it is nice and strong. it has a small grind sometimes when going in reverse. other than that the motor is great. the shift linkage will also be included and the axles also. I will try to post some pix soon.
if interested in buying you might have to wait 2 days or maybe one for i will still have te motor in my car. until i sell it . please shoot any offers . thanks you all
and if you're not in a hurry can you please bump thank you all. for viewing.
sorry forgot to mention that the passenger side axle is busted
SOHC VTEC-E
Honda's next version of VTEC, VTEC-E, was used in a slightly different way; instead of optimising performance at high RPM, it was used to increase efficiency at low RPM. At low RPM, one of the two intake valves is only allowed to open a very small amount, increasing the fuel/air atomization in the cylinder and thus allowing a leaner mixture to be used. As the engine's speed increases, both valves are needed to supply sufficient mixture. A sliding pin, which is pressured by oil, as in the regular VTEC, is used to connect both valves together and allows the full opening of the second valve."
new price 400 OBO.
Modified by mustang5.slow at 8:53 PM 4/17/2007
SOHC VTEC-E
new price 400 OBO.
mustang5.slow
May 23, 2007 10:02 AM
