SHIFTER QUESTION!!!!!!!!
Old Apr 15, 2007 | 04:25 PM
tomato_man's Avatar
Default SHIFTER QUESTION!!!!!!!!
HI. i have a little question about my shifter.
when i put the shifter in any gear,
the shifter moves a lot, it moves as if it were in neutral, but it stays in gear. doesnt slip, just moves a lot.
Old Apr 15, 2007 | 04:28 PM
amej8's Avatar
That's how shifters are. Your bushings might just be torn to shreds (if you even have them in there anymore).
Polyurethane shifter bushings will fix that.
Old Apr 15, 2007 | 04:30 PM
tomato_man's Avatar
Default Re: (amej8)
thanks alot man!!!
thats great help.
ive driven stick shift before, and shifter wouldnt move so much.
thanks
Old Apr 15, 2007 | 04:33 PM
willydup's Avatar
Default Re: (amej8)
thats just a honda box 4 ya
pdiggitydogg's Avatar
No, that is not "how shifters are"...
Check your bushings, check the spring pin ("bitch pin") that secures the linkage to the tranny
Also inspct the sleeve at the base of the lever, where it attaches to the linkage.
Any of these things can make the shifter wobble when they shouldnt
I dont know what kinds of broken down stuff you guys have, but mine does not wobble around in gear at all
Old Apr 15, 2007 | 04:34 PM
tomato_man's Avatar
Default Re: (pdiggitydogg)
umm, gear box?????
Old Apr 15, 2007 | 04:35 PM
tomato_man's Avatar
Default Re: (tomato_man)
hmmm,
i guess ill have a mechanic do that,
thanks
Old Apr 15, 2007 | 04:46 PM
watisjdm's Avatar
yeah either replace the bushing or tighten the actually bolt the holds the shifter and shift linkage together...but make sure not to tighten that bolt to much cause it will make it hard to get in to gear so make sure its snug and not extremly tight where u cant tighten the bolt anymore
Old Apr 15, 2007 | 04:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tomato_man &raquo;</TD></TR><TR><TD CLASS="quote">hmmm,
thanks </TD></TR></TABLE>
not a do-it-yourself person?
if you have eyes, sockets, and time you can do this yourself....
(no offense..i just get annoyed at people that arent willing to try something that they can easily do themselves)
Old Apr 15, 2007 | 05:48 PM
amej8's Avatar
Yes, that is "how shifters are"... Maybe not as loose as the OP states, but all shifters have atleast SOME play. Just because yours doesn't move around at all, doesn't mean other people might have bushings that are more worn or small mechanical problems.
Old Apr 15, 2007 | 06:56 PM
Default Re: (amej8)
Right sure, lets lead him to believe that THIS is normal:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tomato_man &raquo;</TD></TR><TR><TD CLASS="quote">the shifter moves a lot, it moves as if it were in neutral</TD></TR></TABLE>
That is excessive and not "how shifters are"
jb0705
Jul 10, 2009 12:39 PM
DOUBLExDEUCEx22
Jul 8, 2009 02:12 PM
---SPEED-DEMON---
Sep 16, 2008 09:18 AM
integraRS-T
Jun 28, 2007 02:24 PM
Regular Series
Sep 14, 2002 10:41 AM
